Psd has a hick up
Old Mar 31, 2012 | 11:01 AM
Diesel cat's Avatar
Diesel cat
Psd has a hick up
Ok heres one for the brain trust. Ever since I put my chip on from PHP it has had a hickup, only once a day but for a second it just jolts like the engine shut off for a split second. If im at idle it will out right shut off. Do you think this could be something with the chip or cps?
Old Mar 31, 2012 | 12:48 PM
Diesel cat's Avatar
Diesel cat
I figure I'll switch the CPS just to make sure. Should I get one from Ford or Napa.
Old Mar 31, 2012 | 01:16 PM
BlueMule's Avatar
BlueMule
I'd get the one from Ford, aftermarket ones don't seem to last as long as the OEM.
Does the hiccup go away if you unplug the chip? Does it do it on all the programs?
Old Mar 31, 2012 | 04:40 PM
Diesel cat's Avatar
Diesel cat
Thats the wierd thing, I mainly drive in 80dd or 80 tow and it happens only once or twice a day. If it does it at idle and shuts off It has no problem starting again. I'll change the cps and if that doesn't do it I'll unplug the chip.
Old Apr 1, 2012 | 08:00 PM
nossliw's Avatar
nossliw
same thing I had with mine... before the chip...it was the CPS
Old Apr 1, 2012 | 10:26 PM
95_Dually's Avatar
95_Dually
My first CPS did that too. Get it from Ford or IH.
ramrod7373
Jun 2, 2009 08:11 AM
ramrod7373
Jun 2, 2009 07:53 AM
Badluck
Oct 16, 2006 07:57 PM
kbeefy
Sep 8, 2006 11:02 AM
toddncandy
Jun 10, 2006 10:04 AM
