Floor Pans
Old Jul 15, 2016 | 10:54 AM
enikolich's Avatar
enikolich
Floor Pans
I have a '66 F250 with rusty floor pans that I've been living with. I'll be pulling the gas tank for cleaning, so now's my opportunity to get new ones welded in. From my research, it looks like the best pans come from Carolina Classics. Any input on this choice or other suggestions before I place the order?
Any other precautions to take? I will not be doing the welding myself, but worry about the dangers of grease and grime on or around the transmission area. What have the rest of you done?
Thanks!!
Old Jul 15, 2016 | 02:34 PM
dank4120's Avatar
dank4120
I was happy with my floor pans and cab mounts from Dennis Carpenter's.
Old Jul 15, 2016 | 07:21 PM
1964FORDTUF's Avatar
1964FORDTUF
Installing a set of Dennis Carpenter pans right now. High quality product.
Old Jul 15, 2016 | 08:58 PM
The Masked Rider's Avatar
The Masked Rider
Might be a good time to replace the cab mounts also. This will help maintain the cab is level to the frame.
Also, you will need to level the frame with jacks before you weld the new floors in.
Old Jul 16, 2016 | 09:52 AM
enikolich's Avatar
enikolich
Floor pans
My cab mounts are in surprisingly good shape! I know I was very happy with the anti rattle and door seal kits I got from Dennis Carpenter, so I'll take your recommendation for the floor pans as well!
Old Jul 16, 2016 | 07:41 PM
jowilker's Avatar
jowilker
FYI, Carpenter and Carolina Classic parts are the same. Another note, floor pans are the same from 65 to 79, so should you want to cut and weld panels from a newer donor you can.
John
Old Jul 16, 2016 | 08:21 PM
mikec53's Avatar
mikec53
I got mine from ebay. Cheaper than the big name guys and i was quite impressed with the fit
Old Jul 23, 2016 | 10:29 AM
enikolich's Avatar
enikolich
Ive seen some redneck repairs before, but...
What's this??
Hahahahahahahahaha. Who needs new floor plans when you have some tar and license plates.
Old Jul 23, 2016 | 12:06 PM
Tedster9's Avatar
Tedster9
Road signs work good too ha ha
Old Jul 23, 2016 | 04:11 PM
jowilker's Avatar
jowilker
Redneck repair.
John
Old Dec 29, 2016 | 12:29 AM
Grape Nehi's Avatar
Grape Nehi
Northern Redneck Floor Pans
Hey, there are times and places (and weather) when a little redneck engineering it just what it takes to get the job done. 20 yrs ago, I really needed to patch the gapping holes in the floor pans of my 77 Ford van. Im in Alaska so maintaining that barrier between you and the outside elements is certainly advisable. Anywho, I didn't have a welder and had to do it outside in the winter. So I cut up some big tin coffee cans and rolled them out flat. Primed the patches and pop riveted them in place with some silicon sealer underneath. Worked great and that van is probably still running around up here with those coffee can patches. It did make an annoying "oil can" popping sound some times tho
Old Dec 30, 2016 | 05:17 AM
RORZA's Avatar
RORZA
JUST REPLACED COMPLETE FLOOR WITH FIREWALL ATTATCHED FROM 66 2WD INTO 64 CAB. TO MAKE 64 CAB SUITABLE TO SIT ON 66 2WD CHASSIS. LOTS OF SPOT WELDS AND TIME BUT WELL WORTH THE EFFORT. 66 FLOOR GIVES A MUCH BETTER SEATING POSITION AND MORE LEG ROOM.
Crop Duster
Jun 13, 2015 07:47 AM
crazed87bronco
17
Nov 8, 2010 10:31 AM
masterguns2003
Paint & Bodywork
Mar 1, 2007 07:02 AM
coilz347
Jan 19, 2007 12:45 PM
kevkel
Nov 21, 2004 05:08 PM
