White Smoke
Old Jul 13, 2016 | 07:17 PM
DrewRowe's Avatar
DrewRowe
White Smoke
New to the diesel world and idi's. when I start my 7.3 idi every morning it blows white smoke and sometimes when I drive, I have an idea of it burning oil but why so much, anything would help. Thanks
Old Jul 13, 2016 | 11:00 PM
mudmagnet63's Avatar
mudmagnet63
White is unburnt fuel, when I had 2 bad Glow plugs I had a giant cloud of white smoke at start up then it would clear up.
Diesel Smoke tells YOU a Story…
Old Jul 13, 2016 | 11:04 PM
mudmagnet63
Welcome aboard Drew, My IDI has been a learning experience, lot's of good info here from some knowledgeable people ( not Me ) stick around , read the stickies at the top lot's of good info there to get started.
Mud
Old Jul 13, 2016 | 11:05 PM
DrewRowe's Avatar
DrewRowe
Thanks. So would you suggest changing out the glow plugs?
Old Jul 13, 2016 | 11:11 PM
mudmagnet63
No find the offending problem, mine was GP's yours may not be. These ole girls will run forever if maintained. Read through the diesel smoke link and you can see white can be several things. GP's are easy to test with a volt/ohm meter, there is a great write up at the top of the page for testing. Easy to do.
Old Jul 13, 2016 | 11:16 PM
DrewRowe's Avatar
DrewRowe
Okay got it, yeah I'll give it a look to see what it could possibly be, but where at the top is the write up for testing exactly?
Old Jul 13, 2016 | 11:18 PM
mudmagnet63
When you open the idi section at the top of the page are stickies / threads 7 or 8 of them on various subjects, find the year corresponding to your truck and read through the testing procedure there.
Old Jul 13, 2016 | 11:19 PM
mudmagnet63
It say's READ FIRST
Old Jul 13, 2016 | 11:27 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
White smoke can also be coolant ... But I suspect not in this case.
Some white smoke is to be expected at start up, especially if you have Glow Plug issues.
White smoke is super heated unburnt fuel.
However it should not give white smoke while driving!
When you're engine braking (ie off the go pedal and the engine is slowing you down) do you get smoke?
What color?
EDIT
What year is this truck?
-Enjoy
fh : )_~
Old Jul 13, 2016 | 11:29 PM
DrewRowe's Avatar
DrewRowe
It's a 93 and when I'm off the pedal I don't get smoke
Old Jul 13, 2016 | 11:30 PM
DrewRowe's Avatar
DrewRowe
Found it the testing write up, thanks
mcali2
Aug 10, 2016 07:11 AM
adarkang
Nov 10, 2010 04:11 PM
jeffsk7
Mar 8, 2009 11:30 PM
Pud500
Apr 16, 2008 09:52 PM
occb2
May 27, 2007 11:43 AM
