Injector Pump Issues (Runaway like symptoms)
It rolls far too much coal when driving normally, seems like someone has turned up the fuel on this truck, but not sure....but anyways the problem is when going up a hill in a lower gear getting close to redline it will all of a sudden start puking out GOBS of black smoke, literally making the road behind me disappear, and when taking my foot off the pedal it continues to rev up way past redline. The only way I manage to get it under control is to shut the key off and than back on, and after playing with the throttle a little it will start to get back to idle. Once at idle it is rough for about a minute, but eventually it gets back to normal and I can drive off as though nothing happened.
Am from the cummins world
and therefor know nothing about these ford diesels. But to me it seems like a partial fuel runaway, and am curious to see what you all think. Am not against putting in a new fuel injection pump, but would like to see if it is a problem I can fix without throwing a pile of money at it.Thanks for any help you can lend.
Cheers
You'll want to pull the top off the IP, and take a look inside.
Everything should move freely; make sure the metering valve isn't sticking somehow at the end of it's travel.
Would like to turn the fuel down too, think I found a decent read up on how to do it. Any advice before I dig into that can of worms?
- Warm up the truck.
- Go get your favorite Diesel Additive Cleaner/Lubricator.
- Double or even Triple the mix of cleaner/lubricator in the tank while you are out getting it, drive it for a bit, then to home.
- Shut it off.
- Pull the filter.
- Pour it out. (In an environmentally safe manor)
- Fill it up with your choice of Diesel cleaner/lubricator that you picked up. (Diesel Kleen or whatever) Only through the small holes, not the center.
- Re-Install filter.
- Start the truck.
- Let it run for 1 minute.
- Shut it off.
- Let it set for awhile ... Pretty much longer the better, to a point.
- Then take it for a ride.
The point is to get the cleaner/lubricant into the Injection Pump and let it set for awhile. ~12 hours is best.
It should clear up within a tank fuel.
-Enjoy
fh : )_~
i prefer to use automatic trans fluid. i fill the filter, and start the engine letting it idle for 30 to 45 seconds then shut it down and let it sit. as said the longer the better. i like to let the ATF sit in the pump for 2-3 days to really do it's thing, then fire it up and go for a good run.
it is amazing how good it will run after an ATF cleaning.
However I find things like Diesel Kleen work faster and better for the heavy work.
ATF works better as a preventive then a sledge hammer cleaner.
JMO
-Enjoy
fh : )_~
So far from reading around it seems like the culprit could be the lift pump, injection pump or injectors leaking fuel into the crankcase. Any other possible culprits? From reading it seems as though the lift pump has a drain to keep diesel from going panside, so possible a seal in the injection pump. Another thing am noticing is the truck is taking a few more cranks when cold to fire up, which could mean lift pump?
Also took off the air filter and noticed a lot of oil in the intake manifold, also excessive oil in the cdr valve. Not sure if this was the cause to my runaway like problem, but am leaning towards most likely not sense I was able to control it with the key, and if it was running on engine oil it would not have stopped. Put some atf in the fuel tank and put diesel kleen in a fresh fuel filter, let it run for 45 seconds and is now currently sitting for a couple days.
Just doing some reading on these engines and learnt about cavatation, so will be checking the coolant tomorrow to see if I can see any oil in there, fingers crossed that the right additive was put into the coolant by the owner previous.
if the CDR is full of oil and letting oil into the intake, it most likely has failed and needs to be changed.
cavitation is where a cylinder leaks an fills with coolant.
oil in the coolant or coolant in the oil is most often caused by failed o-rings in the oil cooler.
If you've got a ton of oil in the crank case, the engine is going to be splashing it everywhere, resulting in a lot of little droplets of oil in the blowby vapors.
Also, I've never seen an IDI *without* oil in the cdr and intake; there's a reason that the factory specs have a different tolerance on the rearmost cylinder bore.
I'm not saying it's just fine... but be aware that even with a brand new CDR, you will be getting oily vapor into the intake.
Had actually thought that the diesel in the crankcase could possibly be the culprit for the runaway like symptoms, combined with the shot cdr. Being such a high level and thinner oil, as well as being smacked by the crank and splashing about, would make sense that a lot of oil droplets like macrobb mentioned would migrate up into the intake through the cdr. During higher rpms the crank would really make a mess in there, and this is when the problem starts to take off.
So even if you *are* getting diesel/oil sucked into the intake, the governor in the IP is still sticking.
