83 460 same as 79?
Old Jul 11, 2016 | 04:45 PM
78Fordbc's Avatar
78Fordbc
83 460 same as 79?
My 83 460 in my f250 needs some work. So I'm looking at swapping it out with a 79 I have a line on. So my question is are the accessories the same? Will I be able to bolt all my accessories from my 83 onto the same spot on the 79? Anything else I should know before I do this? Thanks in advance!
Old Jul 12, 2016 | 10:30 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
TWO different block casting numbers were used in 1979:
D1VE-6015-A2B has an internal balance.
D9TE-6015-AB has an external balance.
Old Jul 12, 2016 | 10:42 AM
78Fordbc's Avatar
78Fordbc
Is that the flywheel that's internally balanced? The guy said he would throw the flywheel in on the deal.
Anybody know if the accessories are in the same place?
Thanks for the reply
Old Jul 12, 2016 | 11:01 AM
NumberDummy
The D1VE flywheel is internally balanced. The guy said he would throw the flywheel in on the deal.
Both the harmonic balancer and flywheel (flexplate) are specific to either of these block casting numbers. You cannot substitute one for another.
The external balance D9TE block has a weighted crank spacer.
Old Jul 12, 2016 | 11:53 AM
ctubutis's Avatar
ctubutis
No, he's not talking about the flywheel, he's talking about the block. Do your homework here and be sure you end up with the correct combination of parts to use, mismatching parts from the two balancing techniques causes excessive vibration and you will destroy your bearings.
Old Jul 12, 2016 | 12:25 PM
78Fordbc's Avatar
78Fordbc
So if I bought this engine what parts would I need to change? It's a complete engine so I wouldn't be changing any parts unless I have to. Would I just be able to drop it in the way it is?
Old Jul 12, 2016 | 12:27 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Recent thread on the topic ... Motor mounts.
-Enjoy
fh : )_~
PapaBearYuma
19
May 12, 2017 04:27 PM
DrZoom
Jun 20, 2016 05:02 PM
oldmansimek
Sep 23, 2011 11:50 PM
jetblack06
Feb 12, 2010 07:42 AM
Robdogf-100
Aug 31, 2008 01:25 AM
