I've been chasing my tail for months, so finally decided to pull the engine and get to the bottom of things. I bought a truck with a non-original 460. Heads were EFI, front dress was EFI. Block is stamped E9TE. Front dress brackets are not a perfect fit, making me think maybe the block is older than I first thought. There is a spot to mount a mechanical fuel pump....not sure if that remained on newer blocks or not.
The starter chewed up the ring gear right after I bought it, so I went ahead with a new clutch/flywheel/starter, etc. With a new starter, the truck would start ok a few times, then break the starter. 6 starters later, I have the engine out. I learned after installing the replacement 180-tooth flywheel that the externally balanced flywheels have one mounting hole that is a different size than the others, making it impossible to install off-balance. Well, last night I checked and all holes in the crank are identically tapped, meaning I can install the flywheel at any orientation without anything binding. Is it possible to tell if I have an older crank? I have the engine on a stand with the oil pan off so accessibility is not an issue. I am running a ZF5 transmission manufactured in 1988, so I would think a 1988 (i.e. 180-tooth) flywheel would be the right choice in terms of starter alignment. Help!
Great info, thanks. All indications point to having the correct flywheel/starter combo. Guess I need to find another reason that I am eating starters every few weeks....I might take the transmission to a machine shop and have them make sure everything is square.
I had this problem around five years ago when I switched from a T-19 to a Zf-5.
Even started a thread about it...
I ended up shifting the starter rather than replacing the flywheel.
Not certain why, but the tooth form or diameter of my flywheel must be slightly off.
I was planning on having a machine shop fill the bottom starter hole and re-locate it. I am curious to know how you shifted your starter? This is the answer I've been searching for!
I slotted the lower hole and relieved the piloting diameter.
This allowed me to get the proper engagement, where it wont clank going in and doesn't make noise while cranking.
Do you have any pictures or a link to the thread where you did it? How far did you have to move things? If I can do it myself without paying a machine shop to fill the hole and re-tap, all the better. An explanation of how you slotted the hole would be of great value to me!
