Changing front axle u joints?
Old Jun 30, 2016 | 07:41 PM
Dean06919's Avatar
Dean06919
I'm at this point, what's next? Sorry about asking, I've searched but have only found videos and threads on the new body style.
Old Jun 30, 2016 | 08:16 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Remove the spindle. It is a slip fit on the knuckle and probably just stuck. It it with a dead blow hammer or if you have a slide hammer you can use that. Just don't booger up the spindle and the threads. By the way, where did the spindle studs go?
If this is the driver's side the shaft just slides out of the diff. If this is the passenger side, you need to separate it from the stub shaft.
Edit: looked at picture again. This must be the left side so the axle will come out after the spindle is removed.
Old Jun 30, 2016 | 09:31 PM
Encho's Avatar
Encho
The Southernmost Mod
Check my front end write-up, it cover everything up to the removal of the axle shafts: https://www.ford-trucks.com/forums/1...l#post11243835
Old Jul 3, 2016 | 11:02 AM
Dean06919's Avatar
Dean06919
Thanks for all of the help. Encho, the write-up was very helpful, the pictures really helped. I removed the spindle studs to clean them up, lots of rust where I live.
Headed off to the parts store to see if I can rent a spindle puller and slide hammer. The spindle is frozen in place. So far, I've tried:
1. 6 LB sledge with a wood block
2. Jacking up truck, releasing it, allowing the spindle to drop on a piece of wood.
Nothing has worked so far, will try the slide hammer method, hopefully the parts store will have one.
Old Jul 3, 2016 | 01:34 PM
Nothing Special's Avatar
Nothing Special
People say the slide hammer works well. I haven't tried it. The first time I needed to pull a spindle I hadn't heard of that, so I made a puller. I bored a hole in a piece of 3/8" steel plate that just fit over the spindle. Then I put a couple of steel stand-offs between the back side of the plate and the knuckle. I tightened up a spindle nut on it as tight as I could and then hit the plate over each stand-off with a big hammer. Then I could tighten the spindle nut a little farther and repeat the process. This worked very well, but it was a pain to make, so I'd definitely try the slide hammer method first. But just in case that doesn't work...
Old Jul 3, 2016 | 01:43 PM
Dean06919's Avatar
Dean06919
Thanks for the tip NS.
Parts store has the slide hammer, but nobody has the spindle puller. So, I just ordered one online, should be here by next Friday. I really hope the slide hammer/spindle puller works.
Old Jul 3, 2016 | 10:05 PM
Fireball573's Avatar
Fireball573
I used a sharp cold chisel in between the spindle and knuckle on the right side of your picture to get it moving. You can dress up the nick on the grinding wheel. Some people say to smack the spindle around with a big hammer and a block of wood, but I don't like that method because that inner bearing can be hard enough to seat as it is.
vasten
23
Nov 29, 2011 06:15 PM
pete17c
Jul 18, 2010 06:57 PM
mkdubs
Oct 5, 2009 12:31 AM
Sycostang67
General Automotive Discussion
Jun 12, 2009 02:10 AM
high ho silver
Escape & Escape Hybrid
Apr 21, 2009 03:46 PM
