I recently got a 96 f-250 4x4. It had a check engine light on when I picked it up, now it's off.
Where do I plug in the code reader? Both my other 96 150's had the plug in under the dash, this one doesn't
Your f250 is obd1 therefore the data link plug is under the hood near the driver side hood hinge. Might need a different code reader such as an Equus 3145.
The reader above says it's for up to 1995. Will it work on my 96. It has the connector under the hood.
