code reader plug in
Old Jun 29, 2016 | 09:04 PM
blacklab1's Avatar
blacklab1
code reader plug in
I recently got a 96 f-250 4x4. It had a check engine light on when I picked it up, now it's off.
Where do I plug in the code reader? Both my other 96 150's had the plug in under the dash, this one doesn't
Old Jun 29, 2016 | 09:08 PM
rla2005's Avatar
rla2005
Your f250 is obd1 therefore the data link plug is under the hood near the driver side hood hinge. Might need a different code reader such as an Equus 3145.
Old Jun 30, 2016 | 07:58 AM
rla2005's Avatar
rla2005
Drawing of general location of the diagnostic plug:
courtesy of RJM Injection
Old Jun 30, 2016 | 08:09 AM
blacklab1's Avatar
blacklab1
Thank you!!
Old Jun 30, 2016 | 08:27 AM
rla2005's Avatar
rla2005
You can also do it for free: http://web.archive.org/web/201104301...tion.com/?p=13
Count the flashes. Best bet is a code reader to prevent miscounting the codes then misinterpreting the codes.
Old Jul 1, 2016 | 11:48 AM
blacklab1's Avatar
blacklab1
The reader above says it's for up to 1995. Will it work on my 96. It has the connector under the hood.
Old Jul 1, 2016 | 12:26 PM
Lead Head's Avatar
Lead Head
Yes it will work. The F-250, 350 and F-SuperDuty continued to use the same computer system as the '95 and earlier F-150s until '97.
The exception being the California emissions truck, but since your truck has the connector under hood, it's not one of those.
green_95
Jun 14, 2020 12:31 PM
th3Whip
1997 - 2003 F150
Feb 6, 2012 02:02 PM
crawdad
Apr 17, 2007 08:45 PM
007bronco
Jan 15, 2006 07:19 PM
hippy
Dec 26, 2005 09:06 AM
