Smoke screen
Old Jun 20, 2016 | 06:46 PM
roostonu's Avatar
roostonu
Smoke screen
Well my problem went from bad to worse. My 05 started running rough at idle, then smoothed out a bit but started smoking on acceleration a little. At this point it felt like it had more power than ever before and even ran smoother running up to 3k RPM before shifting (manual transmission). But now it's smoking so bad, I can't really drive it. It's smoking white or gray at idle but blowing black smoke on acceleration. I had a cylinder 5 contribution code but with the amount of smoke it's hard to believe only one injector is a problem. Any idea's, I pulled the EGR valve and it doesn't look stuck open but I'm going to replace it anyway.
Old Jun 20, 2016 | 09:19 PM
Per4mance's Avatar
Per4mance
Needs a injector,it will smoke that much. Keep running it and it will hydro lock.
Old Jun 21, 2016 | 09:22 AM
roostonu's Avatar
roostonu
Thanks, I had it towed home last night before something catastrophic happened. I'll update after this weekend.
Old Jun 21, 2016 | 05:23 PM
87crewdually's Avatar
87crewdually
What he said or far worse torch the top out of a piston.
Poorboy04
Aug 31, 2014 09:38 PM
the almighty schmuck
Apr 10, 2013 09:47 PM
Talyn
81
Jul 23, 2010 06:07 PM
beersy50
Nov 15, 2009 07:32 PM
Bergerson
17
Apr 16, 2008 09:56 PM
