Speedometer and odometer not working
Old Jun 9, 2016 | 08:53 AM
Joey1997's Avatar
Joey1997
Yesterday I replaced my speedometer cable, finished it up and took my truck for a quick spin and everything worked fine. Then I went to work and on my way home my speedometer and odometer quit working. Does anyone know what the problem could be?
Old Jun 9, 2016 | 09:07 AM
pgg00's Avatar
pgg00
I'd check and make sure the cable didn't pop out somewhere first
Old Jun 9, 2016 | 10:33 AM
bcamill's Avatar
bcamill
My bet would be it came out behind the speedometer. This is a snap in connection and you must be sure it did so. Otherwise check by the tranny to see if you forgot to put the retaining bolt back in and the tranny popped that connection out.
Old Jun 9, 2016 | 06:37 PM
BTFordGuy302's Avatar
BTFordGuy302
Stick your finger in the hole on the transmission where the speedometer gear goes and see if the gear inside the transmission is worn out. These are plastic and can wear out pretty easily. Just don't get your finger stuck in there lol
Old Jun 9, 2016 | 06:39 PM
BTFordGuy302
That's only if everything is connected still obviously!
Old Jun 10, 2016 | 11:21 AM
bcamill's Avatar
bcamill
Did you get this figured out?
Old Jun 10, 2016 | 11:35 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
These are plastic (maybe yes, maybe no) and can wear out pretty easily.
Speedometer DRIVE gear: On the output shaft of the trans. If this is a 2WD C6, it's not replaceable by itself, as it's made as part of the output shaft.
Speedometer nylon DRIVEN gear: Located at the end of the cable, nylon teeth can strip / Available from Ford (16 thru 21 tooth gears available) & auto parts stores.
Old Jun 10, 2016 | 06:28 PM
BTFordGuy302
That's how it is in mine, 4-speed manual. When I changed mine, there were no teeth on it whatsoever.
Old Jun 17, 2016 | 04:49 PM
captanron's Avatar
captanron
Speedo gear
Hello. Just wanted to say on my 80 custom with man 3od. Hope you kept the original nylon gear because it has numbers on it specific to your application. And when you order a new one your gona need to know what side of the tranny your speedo cable goes into. I searched everywhere for a new one and cant get them anywhere except cj pony parts on the interweb. Hope this helps.
Old Jun 17, 2016 | 06:00 PM
Gary Lewis's Avatar
Gary Lewis
I think you are mistaken. First, all of the transmissions I've seen for these trucks have the speedo gear going in on the driver's side. And that includes the transfer cases.
As for sources, these gears are available practically everywhere. A friend of mine picked one up at our local O'Reilly's - in stock - and we live in a small town in Oklahoma. But, here are a few other sources for c0dz 17271-A from this search:
1968bumpside
Mar 16, 2012 12:36 PM
4601ton
Jan 5, 2012 07:46 PM
hittman1422
Apr 3, 2009 05:34 PM
hedgeapple
Aug 4, 2004 01:52 AM
banditjax
Jul 22, 2003 04:15 PM
