Dash light problems
Old Aug 16, 2003 | 01:28 PM
coolmint94's Avatar
coolmint94
Dash light problems
Ok, I just got myself a 1979 F-150 4x4 with a 400 in it. When I got it I checked to see if the blinkers worked and what not, well my blinkers work but I think thats cause when I was driving the wire became attached to the body so they work but my problem is i have no indash lights for night driving. What I need to know is how to get new bulbs in, Im pretty sure the wiring is good and the bulbs might just be burned out.
Thanks for all the help,
Daniel
Old Aug 16, 2003 | 01:37 PM
UglyF250's Avatar
UglyF250
Dash light problems
Well, I'm no expert on the subject, but I recently took my interior apart ('73 F250), and I guess you'll just have to start unscrewing the dash panel and pulling off control *****.
The ventilation ***** pull straight off, though you might want to wear a pair of gloves. Inside the plastic **** is a metal clip that slides out and can cause a nasty scrape.
The Wiper **** on mine pulled off the same way, but the headlight **** was a different story. Thanks to this website, I learned that you have to reach up under the dash where the light switch is and feel for the box that houses the headlight switch. On the top of the box, about in the middle there is a little button you have to feel for. Push this down while you pull out the headlight ****.
After that, I think you can pull the dash trim panel, then you can start to unscrew the guage cluster. Be careful when you pull it out, as there are several wires connected to the cluster.
Hopefully someone else will chime in here and verify or discredit my information, and hopefully elaborate on what knowledge I have gained.
Good luck, and please remember to be very specific when you title your posts. "Need Help" is kinda generic, and you might not get the answer you're looking for.
Old Aug 16, 2003 | 01:43 PM
beeboy's Avatar
beeboy
Dash light problems
It can also be the headlight switch, I know my dimmer is flaky, my lights are either off or on, and nothing in between.
Old Aug 16, 2003 | 04:32 PM
Torque1st's Avatar
Torque1st
Posting Legend
Dash light problems
All of the bulbs being bad is unlikely. Your dimmer switch is probably out. If you take your instrument cluster out use the search function here and find out all of the little repairs and improvements you can do.
Old Aug 18, 2003 | 09:24 AM
73Custom's Avatar
73Custom
Dash light problems
Have you tried twisting the headlight ****? Some people don't realize that adjusts the brightness of the dash lights.
Marty
Old Aug 18, 2003 | 12:25 PM
dfisher1's Avatar
dfisher1
Dash light problems
Cool,
Be careful and gentle with your Instrument panel (IP). They get rotten over the years and removing the bulb holder (small, black, plastic, ***** in the back of the IP) can be worse for the IP than driving without dash lights. I have had to remount the IP and gentling adjust the bulbs from under the dash. This is not easy but after a dozen tries you'll eventually get it right. The replacement bulbs are the same as the marker lights on the front and rear fenders.
KingFisher
Old Aug 18, 2003 | 06:03 PM
blinkjs's Avatar
blinkjs
Dash light problems
When I installed an aftermarket radio in my 76' I had the same problem. Turned out what I thought was a ground was for the original radio's lights. As soon as I reground the wire properly and replaced the fuse I haven't had a problem in 10 years.
Old Aug 18, 2003 | 10:29 PM
clean79150's Avatar
clean79150
Dash light problems
Coolmint,
I had the same problem with lights in the dash not working. Mine wasn't as bad as yours, a few of mine still worked. The problem with mine was that the back of the gauge cluster was rotted and crumbled away to the point where there was no contact being made by the light fixture and the printed circuit.
Take your gauge cluster out and inspect the back panel and printed circuit. I had to replace the gauge cluster back panel to repair mine.
Check with Mil1ion, he was a big help to me.
Old Aug 18, 2003 | 11:16 PM
Txquadhunter24's Avatar
Txquadhunter24
Dash light problems
My 78 and 79 I had same Trouble as Clean. I swapped in a good IP and everything lite right up. Even a few gauges That didn't work before.
rossseger
Nov 3, 2014 02:09 PM
drewduncan15
Dec 31, 2012 05:38 PM
vol1966
Feb 20, 2011 11:01 AM
diesel77
Apr 26, 2010 08:06 PM
wmsteward
Oct 15, 2007 11:44 PM
