Tail light problems
Old Dec 23, 2012 | 09:02 AM
drewduncan15's Avatar
drewduncan15
Tail light problems
I've been having trouble with my tail lights, i bought all new bulbs both 1156 and 1157. i think what i have right now is just my tail lights light up while i have no blinkers. is there anything i can look at or check before following my wires all the way up? My front right blinker will work and the arrow in the dash will blink like it should. when i turn on my left blinker the dash light just stays on without blinking and neither light blinks.
Old Dec 23, 2012 | 09:27 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Did you check the left front parking light bulb? On these trucks, if a light is blown, the t/signal won't flash on that side. On the rear, check the grounds first. That tends to be a common problem with these trucks.
Report back and we'll go from there.
Old Dec 23, 2012 | 05:06 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Same taillamps/sockets: 1974 F100/350 Stylesides from serial number T80,001 / 1975/79 F100/350 Stylesides / 1975/91 Econoline / 1978/79 Bronco.
Old Dec 23, 2012 | 09:05 PM
drewduncan15
checked the front light on the left and it seems to be fine. the only turn signal i have is the front passenger side i don't know what to do
Old Dec 31, 2012 | 04:35 AM
joewelds's Avatar
joewelds
I have a '78 F150 with this problem as well, I ended up having to replace both rear tail light sockets. I also took apart all four grounds and used a stainless steel brush to clean the attach point and ground wire terminals. Lube them with dielectric grease and reassembled. Works great.
Old Dec 31, 2012 | 08:36 AM
drewduncan15
yeah i think my sockets will need replaced soon. i got everything to work except front drivers side.
Old Dec 31, 2012 | 04:39 PM
joewelds's Avatar
joewelds
It's pretty easy. And fairly cheap. $5 for the socket. And a couple wires.
Old Dec 31, 2012 | 05:38 PM
4x4 Bart's Avatar
4x4 Bart
Just a heads up,
If you buy aftermarket replacement sockets, make sure they don't space the bulb to close to the tail light lens or it will melt a hole in the lens.
Gribbler101
Jun 14, 2016 05:13 PM
Microchudd
Apr 28, 2012 06:47 AM
F350flatbed
Jan 3, 2005 09:22 PM
isaz
Dec 15, 2003 02:28 PM
loserpdenton
Electrical Systems/Wiring
Feb 22, 2003 04:49 AM
