Blinker Issues
Old Apr 26, 2010 | 11:40 AM
diesel77's Avatar
diesel77
Blinker Issues
I have a 78 f-250 almost restored...down to lights and wiring. The issue: When my headlights are on, my left blinker does not work and the blinker arrow on my instrument cluster is solid green. When my head lights are off and the left blinker on, all my blinkers (F/R, L/R) flash very dimmly. The right side blinker works fine all the time.
Also, when my headlights are on there is juice to the left front marker light/blinker (used a bulb tester) but the bulb will not light up (I have triple checked the bulbs and they are good).
Any ideas on where the short/issue could be located?
Thanks~Frustrated in the shop
Old Apr 26, 2010 | 01:42 PM
lance65's Avatar
lance65
Change you left side bulbs. I just had this happen to me. One of my turn signals was "going out" the finally went out,changed the bulb and was just fine. Good Luck
-Lance
Also check for a bad connection in the socket.
Old Apr 26, 2010 | 02:26 PM
Tomtom155's Avatar
Tomtom155
First off you have a ground problem. I just had this issue and I had to replace the pass. side blinker and park light socket. Problem solved for me....
Old Apr 26, 2010 | 02:54 PM
diesel77's Avatar
diesel77
Thanks!
Thanks for the feedback. I ordered new sockets so hopefully that will cure the problem.
Old Apr 26, 2010 | 08:06 PM
smitty-n-iraq's Avatar
smitty-n-iraq
That fixed my blinker issues as well. The sockets were so corroded inside that it was just better to replace them.
rossseger
Nov 3, 2014 02:09 PM
marks69
15
Feb 20, 2010 11:22 AM
70_f100
Electrical Systems/Wiring
Mar 6, 2006 12:01 PM
cjf5150
Oct 18, 2005 11:18 AM
dfisher1
Aug 5, 2004 12:45 PM
