Sponsored by: Auxito
2003 F150 filter
Old Jun 5, 2016 | 09:54 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
2003 F150 filter
I tried to change my filter today and I couldn't get the outlet side off after removing the clip, is there a trick to it.
Denny
Old Jun 7, 2016 | 08:49 PM
steve(ill)'s Avatar
steve(ill)
I believe there is a toothed washer inside the fitting. After you remove the clip, the teeth still grab the steel tube. You need to have an insertion tool that slide in between the gas line and the plastic end fitting and spreads the teeth, then pull... you can get an auto store.
Old Jun 7, 2016 | 08:51 PM
steve(ill)'s Avatar
steve(ill)
3 PC Quick Disconnect Tool Set AC Fuel Line Transmission Parts Chrysler Ford GM | eBay
Old Jun 7, 2016 | 10:47 PM
toby tough's Avatar
toby tough
I bought one of those and it was plastic. They didn't have the metal ones. Anyways the end broke off when I tried to use it. Finally found a metal one and it works fine. Sometimes if the fitting faces forward it can pick up some crud up in there which causes some difficulty.
Old Jun 11, 2016 | 04:39 PM
enriched&beyound's Avatar
enriched&beyound
I'll echo the thought of crud getting built up in there. The 1st time changed my fuel filter, I had one heck of time getting those fuel filter release gadget tools in there (even if it felt like it was in there & yes they were metal ones). I ended up with repeating twisting the filter back and forth on the line with spraying penetrating spray applications until it move a bit more freely then the special fuel line tool worked.
Old Jun 11, 2016 | 11:07 PM
blupupher's Avatar
blupupher
I changed mine using a Sharpie cap.
Old Jun 13, 2016 | 08:45 AM
rvpuller's Avatar
rvpuller
Finally got the thing changed, what a pain and why did they put it over the cross member
After I got it out it rattled so I cut it apart and the filter was no longer attached to the filter housing. It was really dirty as you can see so it was attached at one time, it had been changed at sometime because it was made in China. You can also see the tool I used.
Denny
Old Jun 13, 2016 | 06:17 PM
toby tough's Avatar
toby tough
The one fella there had the video and his cap tool seemed to work good. What I don't understand is he will only change his fuel filter once in a lifetime? I change mine once a year on both my trucks. And I change the oil whether it needs it or not.
Old Jun 17, 2016 | 04:48 PM
enriched&beyound
I'm on a 3-5 year plan myself for the fuel filter, because I don't drive that meany miles
Spotty
1997 - 2003 F150
Feb 7, 2019 02:12 PM
Clints66
Nov 12, 2010 07:19 PM
fishnstash
1997 - 2003 F150
Oct 16, 2005 05:45 PM
Big-Red-Lariat
1997 - 2003 F150
Sep 23, 2005 08:41 AM
billj6
1983 - 2012 Ranger & B-Series
May 7, 2005 09:16 AM
