The EPC circuit is not applicable to your truck, since you don't have an electronically controlled transmission. I believe in this case, the code means have a complete sensor failure - perhaps the ECT?
And also code 51 is coolant temp sensor circuit open I believe and I have found the one on the thermostat but I'm guessing there is two cause the one on the thermostat doesn't affect the gauge
