rocker arm noise
Old Apr 25, 2010 | 10:30 PM
Brando_21's Avatar
Brando_21
rocker arm noise
ok, I built a 302 +.060 for my 73, it has a flat tappet xtreme energy 284cam 240in 246ex duration at .050, .541 .544 lift, i am running harland sharp 1.6 roller rockers, this is my first time running harland sharp rocker arms and they seem a bit noisy to me. I set my rocker arms while the engine was still on stand but after break in i decided to check the noise by checking the rockers by hot adjustment, the noise im hearing is much quiter than the normal excessive lash type clunking noise because as soon as i backed the first lifter off to get to make noise to return to zero lash i could tell a definite tone and volume difference, this noise is not from loose rockers but sounds more just like the rockers themselves? The last few sets ive ran werent this loud i thought, but there again they were louder exhaust so harder to hear and they had steel valve covers where as these are aluminum, they noise doesnt get louder with rpms but it doesnt stop either, just speeds up obviously, is this noise typical and i just being paranoid?
Old Apr 25, 2010 | 11:02 PM
393STROKER's Avatar
393STROKER
You may want to check your springs for coil bind,with that cam you might need different springs to handle the additional lift.
Old Apr 25, 2010 | 11:07 PM
Brando_21's Avatar
Brando_21
the heads are built with 2.02 1.60 valves with 986-16 springs which are comp specific to the cam, it runs great, revs high with no problems i really think these rockers are just that noisy was just hoping someone else might have experience with these rockers. thank you for the suggestion
Old Apr 25, 2010 | 11:20 PM
johnboy427's Avatar
johnboy427
I have never had excessive noise with Harland Sharp rockers. Mine have been as quiet as stock. If they are making noise I would think you got a bad one. Does it sound like its one or do all of them make the noise?
-John
Old Apr 25, 2010 | 11:34 PM
393STROKER's Avatar
393STROKER
Whats your pre-load measurments on the lifters? I think it`s supposed to be .030-.060. Also check spring to rocker clearance.
Old Apr 26, 2010 | 09:14 AM
Brando_21's Avatar
Brando_21
set preload according to comp specs, well during assembly but then did hot adjust just to double check myself, found the rocker... was having hard time finding it so just started swapping one for one from bank to bank until the noise jumped sides, thanks everyone, gotta love warranty lol
Old Apr 26, 2010 | 02:46 PM
MBDiagMan's Avatar
MBDiagMan
Did you check for proper push rod length and put in the correct length push rods?
SANDDEMON08
6.4L Power Stroke Diesel
142
Jul 18, 2016 09:42 AM
Montync
16
Apr 3, 2016 01:55 PM
BaronVonAutomatc
28
Apr 2, 2016 05:16 PM
IDIoit
22
Nov 23, 2015 10:32 PM
jamies460
Jun 24, 2007 10:39 AM
