Modular V10 (6.8l)
Ethanol in my v 10?
Old 05-26-2016, 11:25 AM
KP1001's Avatar
KP1001
KP1001 is offline
Ethanol in my v 10?
Should I be using fuel additive when using e15 or 85?
06 v 10
Old 05-26-2016, 08:17 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
You should probably go read your owner's manual.
Old 05-27-2016, 12:05 AM
Sam I Am's Avatar
Sam I Am
Sam I Am is offline
06 v 10
A) Super Duties never got flex fuel from the factory. If yours has been altered, you will need to contact whoever did that to find out exactly what fuel is safe.
B) Under normal use you should never need fuel additives if you are using the correct fuel that your engine requires, which you are probably not based on you feeling the need to ask that question.
Old 05-27-2016, 07:29 AM
rvpuller's Avatar
rvpuller
rvpuller is offline
Ethanol in my v 10?
The 6.2 SD is Flex Fuel from the factory but the V10 wasn't.
I've never found a need or reason to at fuel additives to any gas motor that has been running good clean fuel, the ethanol in itself is a good solvent and will clean or keep your system clean.
Denny
Old 05-27-2016, 07:47 AM
Diamnd1's Avatar
Diamnd1
Diamnd1 is offline
Ethanol In Your Gasoline Tank: The Pros And Cons
One of many articles on ethanol fuel.
Old 05-27-2016, 08:13 AM
rvpuller's Avatar
rvpuller
rvpuller is offline
Ethanol in my v 10?
I find it funny that they keep on saying farm ground that would be used for growing food but in real life the farm ground that is used for corn for ethanol production was and is still used to grow field corn used for feed mostly for cows. But after the corn is used for ethanol the mayor byproduct is a high protein feed that is feed to cows so in the end it's being used twice.
Denny
Old 05-27-2016, 09:15 AM
projectSHO89
Now, if we could capture all the methane that the cattle produce digesting that feed, could we call it a "triple usage" of that farmland since methane is also a viable energy product?
Old 05-27-2016, 09:40 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Thank you for being the first to post a REAL ANSWER, and not a glib reply
Old 05-27-2016, 09:45 AM
Diamnd1's Avatar
Diamnd1
Diamnd1 is offline
There is probably some college funded program that is trying to fit a cows rear with a tube and reservoir that stores it and can be transferred to a large transportation tank. I grew up on a farm and its absurd what the gubment forces upon farmers. It is difficult enough to make a living with out all the bureaucracy.
Old 05-27-2016, 09:57 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
And now, the politics can STOP.
Move along, nothing to see here
F350FordToy
6.2L V8
07-21-2021 07:50 PM
mcrews
2009 - 2014 F150
07-15-2018 04:35 PM
Monahan77
09-07-2015 09:45 AM
silver05fx4
Alternative Fuels, Hybrids & Mileage
06-20-2008 11:56 PM
PSDLOVER
163
06-11-2006 11:13 PM
Quick Reply: Ethanol in my v 10?
