Code p1316 injector driver module thrown when engine is cold?
Old May 25, 2016 | 01:49 PM
jstihl's Avatar
jstihl
Hey guys, I keep getting my SES light coming on in the morning when my engine is cold. I'm getting code p0603 and p1316. I was told the first one is just from using my tuner. The second code is the injector driver module, just trying to figure out what is causing it to throw the SES light only when cold. Any help would be greatly appreciated , thanks
Old May 25, 2016 | 04:24 PM
Pikachu's Avatar
Pikachu
A P1316 means the IDM has codes stored. Run a KOEO or injector buzz test to see what codes the IDM has stored.
Old May 26, 2016 | 06:58 PM
jstihl's Avatar
jstihl
I am now getting a p0605 code, after looking it up there is alot that can cause this code. I guess the pcm isnt operating properly. One of the symptoms of this code is poor fuel economy, which i have. After researching the other code i had, all signs were pointing to the UVC Harness. I took a temp gun and shot my exhaust manifolds, and sure enough there was a significant difference. Driver side was around 190 and passenger side was around 130. So would this suggest doing the quarter trick to the passenger side? Also if it is the UVC Harness , would this throw the p0605 PCM code? Pretty sure i read that one of the causes of this code is faulty wiring. The engine runs a little rough and sounds different on cold starts in the morning, but after about 10 minutes ses light goes out and it runs fine the rest of the day. Please tell me this will fix my fuel economy issue, ive tried everything. Thanks for any advice
Old May 26, 2016 | 07:37 PM
jstihl's Avatar
jstihl
Also wanted to add that i did an injector buzz test and couldnt really tell if one sounded muffled more than others so i decided to shoot the exhaust manifolds with temp gun
Old May 27, 2016 | 01:56 AM
AllaboutMPG's Avatar
AllaboutMPG
also check the wire harness for the 42 pin connector were it goes across the the driver side valve cover to make sure it's not rubbing through wires.
Were all 4 cylinders on the passenger side reading lower temps?
Old May 27, 2016 | 06:05 AM
jstihl's Avatar
jstihl
I only shot one part of the manifold, but will try to shoot all cylinders today
Old May 27, 2016 | 06:30 AM
Tugly's Avatar
Tugly
UVCH link in my signature will help.
copsey
Apr 20, 2018 07:37 PM
kt19
Oct 27, 2014 05:37 PM
PJ-Hunter
16
Nov 25, 2013 02:37 PM
btsb032304
Sep 3, 2010 07:22 PM
dt444e
Sep 27, 2009 06:03 PM
