Is my #8 injector suppose to be different from the rest?
From my understanding the AE was developed to reduce the noise the injector made in the number 8 position. The AD and AE are interchangeable based on my research.
Words from RiffRaff
Alliant 'AE' Fuel Injector Ford 7.3L Powerstroke
Words from RiffRaff
The "AE" is a "long lead" injector that Ford installed in #8 only, as a TSB on earlier trucks and as factory production on the later 7.3L's, in an effort to cure "cackle" issues at idle. This is/was a result of the deadhead fuel rail design.
My 2000 had all AD injectors when I pulled them and swapped in larger 180cc single shots (modified AA code).
Technically, it doesn't really matter whether you run all AD, or put the AE in #8; except that the pcm needs to be flashed with appropriate strategy. So, since your pcm is programmed for an AE in #8, you need to either stick with that, or have the PCM flashed for it having all AD's. - Correction- I see you have a DP Tuner chip. Call them up and see about updating the tune if you want to ditch the AE.
For that matter, if you are going through the time and expense of doing new injectors, why are you bothering with stock replacements, when you can get upgraded/larger single shots for not much more. I got my 180cc singles from Full Force Diesel in TN. Ryan was great to work with. He literally spent hours on the phone with me.
EDIT: Especially considering that you already have an S&B intake, and a 5" exhaust. Those mods are virtually worthless with only stock injectors. You simply can't use much more air or exhaust then stock, with the limited fuel flow potential of the stock AD/AE injectors. You've already spent the money on those supporting mods, so put them to use with bigger injectors. And maybe do a minor turbo upgrade, such as a rebuild with 360deg thrust bearing and a WickedWheel2 billet compressor wheel, and a tuning update for the new parts. It will make a big difference. And realistically, if you don;t do it now, do you really think you'll buy another set of injectors later? Now is the time. Pull the trigger on some power!
I'm not looking to make crazy power with my truck. It's my daily driver and is used to tow our Rv. I just want to be able to get in, turn the key and go. I wanted a better intake than stock and I liked the look of the S&B plus it sounds good. I also liked the look and deep tone of the 5" exhaust. Whether or not these"mods" are worthless I really don't know? But with the DpTuner she moves along just fine for me..
Besides when I'm in the mood to drive something with power I take out my 2013 Shelby GT500.
Words from RiffRaff
Words from RiffRaff
I just wish I new that when ordering. I just got on RiffRaff's website and it said late 99-03's use AD injectors. So I ordered 8 not knowing one was different.... Now I'm just waiting for Clay to call me back to see if I can swap an AD for AE.
Thanks guys..
I would have done the exact same thing. I like to learn from the experiences of others if I can, and this is one of those times.
Originally Posted by Walleye Hunter
I would like to know what this 'longer lead' is on that AE injector. There are no wires attached so it's not a lead wire, there are no fuel lines attached to it so it's not a fuel lead. What is that lead?
Originally Posted by TSB 00-22-1
In addition to replacing the injector,
thePowertrain Control Module (PCM) must be
reprogrammed to prevent the #8 injector from
flagging a false Cylinder Contribution Test code
during future diagnostic tests.
They should be interchangeable, yes. I'm pretty sure I saw @cleatus12r post somewhere about this subject, too. Maybe he'll notice this and comment on the calibration. The only real info I have is what Ford published, whereas he's seen the actual code in the PCM. I can say this, I have a mix of AB and AD injectors in my engine with an AD in #8, and there's nothing noticeable in the data or the way it runs that would make me think it's any problem.
