can I get a vin code decoded please?
Old May 19, 2016 | 09:07 PM
fordboy_52's Avatar
fordboy_52
need to know what axels and if it has front or rear disc?
thank you
Old May 19, 2016 | 09:12 PM
fordguy2100's Avatar
fordguy2100
This should help you decode everything http://www.fordification.net/tech/vin.htm
As far as which axle you have, it should be stamped on the housing in the bottom right corner next to the pumpkin. May take a wire brush and cleaner to see
Old May 19, 2016 | 09:29 PM
HIO Silver's Avatar
HIO Silver
A decoded VIN won't provide that information.
The VIN only provides the model, engine code, manufacturing plant, and consecutive unit number.
However, the warranty plate riveted to the rear face of the driver's door does provide the codes necessary for determining how the truck was originally delivered... unless the door has been swapped and the warranty plate wasn't transferred.
Old May 19, 2016 | 09:34 PM
blackjack33's Avatar
blackjack33
^ what HIO said
That pic shows is that the truck is a...
1979 F150
6cyl engine
made in Kansas City
April '79,
4x2 given the GVWR
You'll need to post the door tag which is riveted to the door, black and silver for more info.
Old May 19, 2016 | 10:43 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
F150 ='s 9" rear end, March 79 so 99% sure front end has single piston caliper disk brakes and drums on the rear.
And just so you know that sticker is NOT the vin tag, it is the Safety Certification sticker.
Old May 19, 2016 | 10:56 PM
HIO Silver's Avatar
HIO Silver
Any of yall have any idea what year(s) the Dana 44 was used as a rear axle?
Old May 19, 2016 | 11:02 PM
77&79F250's Avatar
77&79F250
Dana 44 under the rear of a Ford truck, never as far as I know...https://en.wikipedia.org/wiki/Dana_44 But what do I know? lol
Old May 20, 2016 | 05:43 AM
gatorfor88's Avatar
gatorfor88
1977-'79 Ford ½-ton pickups 1959-'68 2WD and 1962-'69 4WD Ford ½-ton pickups also used in Broncos up til 77
Old May 20, 2016 | 08:21 AM
77&79F250's Avatar
77&79F250
Here is ND's take on it from way back when. https://www.ford-trucks.com/forums/7...ml#post6514873
Old May 20, 2016 | 01:58 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1951/56, 1959/67 with Limited Slip and on some 1977/79 F100/150's (with/without Limited Slip).
1959/67 F100's with 9" were not available with Limited Slip, 1968 was the first year.
Some 1963/66 F100's also have Dana 60.2 .. some 1966/68 F100's have Dana 60.3 .. both with Limited Slip, but neither is a Dana 60.
No 1966/77 Bronco had a Dana 44 rear axle.
Pic: 1977/79 F100/150 Dana 44-3 rear axle applications:
Old May 20, 2016 | 02:16 PM
NumberDummy
Originally Posted by fordboy_52
^ Safety Standard Certification Label ^
Production Date: 3/79
6,050 lbs. Gross Vehicle Weight Rating.
F15 = F150 2WD Pickup.
B = 300 1V I-6.
K = Kansas City MO Assembly Plant.
EJ1014 = 1979.
Warranty Plate riveted to the left door face below the latch has the TRANS, AXLE and etc. codes.
62-05ford
19
Apr 19, 2014 10:59 AM
johnmel59
Oct 25, 2013 12:47 PM
MANSON
Large Truck
Oct 26, 2010 11:54 AM
down2earth1928
30
Aug 13, 2009 08:04 PM
tlh20fan
Jun 25, 2009 10:57 AM
