Modular V10 (6.8l)
Misfire!
Old May 17, 2016 | 08:45 AM
Mrdbraun's Avatar
Mrdbraun
Misfire!
Misfire!
Help! I have a 97 E super duty motorhome with the triton v10.
At first i had a bunch of codes saying lean bank1 and lean bank 2, as well the misfire codes on 3,6 and 8.
P171
P174
P303
P306
P308
Changed the COP (coil on plug), same codes.
Changed plugs, same codes.
Changed PCV, same codes.
Changed fuel filter, both O2 sensors, same codes.
Changed DPFS, same codes.
Changed injectors, same codes.
Changed MAS, P171 and P174 went away, started running consideribly better. Still missfiring on 3,6 now 7 and 8.
Passed smog tho..
Hooked up vacuume gague to see if possible worn or broken valve springs.
Vacuume shows about 21" at idle, shoots to 0" then 25" and back to 21" when quickly rev'd. Needle vibrates about 1", (21" to 21.5/22").
Ive read this indicates vacuume leak..
I've sprayed starter fluid like crazy on all hoses i can see, no engine speed change..
Any thoughts are appreciated!
Old May 17, 2016 | 10:37 AM
R&T Babich's Avatar
R&T Babich
Did this start happening all at one time or gradual?
Might be a typo - did you change all the COPs or just one?
Maybe a sensor is intermittent - throttle position or crankshaft position.
Old May 17, 2016 | 12:27 PM
Mrdbraun's Avatar
Mrdbraun
Changed all suspect COP, (3,6,8, from codes that popped) this was all at once as i bought it in vegas and drove back to CA. It had sat for quite a while. A number of vacuume hoses were completley dry rotted..
Old May 17, 2016 | 01:31 PM
R&T Babich's Avatar
R&T Babich
Usually the lean codes are a vacuum leak
I'm still fighting a P0171 on our 2003 5.4l Exped which may be a cracked intake.
The misfire codes are usually electrical - bad/wet spark plug boot/spring, cracked coil housing, poor connections.
Have you checked grounds - battery, PCM, engine to frame?
How do the COP connectors look?
Reseat the PCM connectors.
What is the system voltage?
What is the voltage getting to the COPs?
How is the fuel pressure?
Old May 17, 2016 | 02:10 PM
Mrdbraun's Avatar
Mrdbraun
Fuel pressure is good, going to hook gauge back up and test under load. Will check connections next, thanks!
Old May 18, 2016 | 10:31 AM
rock2610d's Avatar
rock2610d
Does it use much oil?
Lower intake plenum can fill with oil and cause issues?
Old May 18, 2016 | 10:54 AM
Mrdbraun's Avatar
Mrdbraun
Havent had it long enough to notice oil loss.. Will look into tho.
Old Feb 7, 2017 | 07:30 PM
jmccracken1214's Avatar
jmccracken1214
Cleaned the MAF sensor last night, reset codes... Came on tonight on my way home from work, the p0171 went away. Only showing p0174 now.
any ideas ? I'll check the torque app tomorrow. Too tired from long work day
Old Feb 7, 2017 | 09:50 PM
R&T Babich's Avatar
R&T Babich
The P0171 may come back.
They don't necessarily get set at the same time.
I finally found the cause of my P0171 "only" code.
I had replaced the exhaust Y-pipe awhile ago because the CATs were bad.
The passenger side pipe to manifold flange bolts had worked loose or the connection seated better after use.
I thought an exhaust leak I had was a broken stud on the driver's side.
When I fixed the stud the exhaust leak didn't go away.
I checked all the exhaust bolts and found the loose flange bolts on the passenger side.
Tightened the bolts - exhaust leak fixed and no more P0171 code.
Old Feb 8, 2017 | 09:19 PM
Earlthegoat2's Avatar
Earlthegoat2
Do the motorhomes have the PCV hose under the throttle body that always gets a hole worn in it? It's pretty much the number one cause of lean codes on V10s
Might want to check that out if it is relavent to this situation.
Mrdbraun
May 17, 2016 11:19 AM
caprisecca
Jul 2, 2014 05:37 AM
77mud
May 27, 2014 07:29 PM
88f150302
1997 - 2003 F150
Dec 14, 2010 11:43 AM
jsmallwood_2000
Jan 15, 2008 11:16 PM
