couple engine codes
Old May 25, 2014 | 10:27 AM
77mud's Avatar
77mud
Alright working on my mothers 00 EB expedition with the 5.4.
I read the codes last weekend and it had P0171 and P0174 it also had a very bad idle to it, I cleaned the maf and switched it with one I knew worked, no change. I tracked down to a very badly leaking pcv elbow on back of the intake. Well today I replaced the elbow, it definitely calmed down some. I rechecked the codes and found several more. P0136 p0156 p1131 p1151 p0171 and p0174. I googled them all and they seem to be mostly o2 sensors and the bank 1/2 lean. Im hopping they won't come back. It also had a p0304 which I know is hole 4 misfire and could be the jump that were still feeling.
But in case the codes come back (just disconnected the battery to clear codes) what else can I look at that would cause all these codes? I'll have her drive it some to see what codes come back and put them up here when/if they all come back.
Old May 26, 2014 | 12:11 PM
77mud's Avatar
77mud
Alright the bank 1/2 codes and the misfire #4 didn't show back up yet.
Any ideas?
Old May 27, 2014 | 05:17 PM
77mud's Avatar
77mud
Anyone????
Old May 27, 2014 | 05:54 PM
dclack's Avatar
dclack
Misfires are usually attributed to a bad COP. Might think about changing the plugs and coils.
Old May 27, 2014 | 07:16 PM
77mud's Avatar
77mud
The mis fire hadn't came back as of yesterday, but that's really the least of my concerns. The other 4 codes are what I'm un sure of.
Old May 27, 2014 | 07:29 PM
pdqford's Avatar
pdqford
Originally Posted by 77mud
Anyone????
The vacuum leak caused the 171/174 codes, which prolly also caused the misfire and the 136/156 codes as it threw the downstream HO2S out of calibration limits, and also caused the upstream HO2S to stick lean becasue the vacuum leak caused it to actually run............LEAN.
I think your good to go.
rogerranger2122
General Automotive Discussion
Apr 11, 2018 07:02 AM
Belgar
Modular V8 (4.6L, 5.4L)
Jan 10, 2015 08:14 PM
caprisecca
Jul 2, 2014 05:37 AM
77mud
1997 - 2003 F150
May 29, 2014 03:08 PM
iateatoad
13
Dec 8, 2012 10:35 PM
