Ignition switch issues
Old May 16, 2016 | 10:29 AM
candoo's Avatar
candoo
I had my 1966 F350 fail to start on the weekend. Finally got it down to the switch. I did no work previous to the no start and by twisting the switch I got it operating. Last year I replaced the locks and switch with no issues but looks like the switch is flaky. Can I get a NOS switch and how do I get the switch out of the dash.
Old May 16, 2016 | 08:01 PM
Mason R's Avatar
Mason R
To remove the switch from the dash
1. turn the key to the Acc position
2. Insert a small piece of wire or paper clip into the small hole just below the key and depress the small spring loaded button inside the lock
3. Turn the key even farther counter clockwise while pushing in with the paperclip.
4. Now pull the key straight out and the whole lock cylinder should come out with it
5. Then reach under the dash and push the switch towards the seat and twist it a quarter turn while holding the bezel to the dash with your other hand.
Then The switch should just come right out from under the dash
Old May 16, 2016 | 09:00 PM
Tedster9's Avatar
Tedster9
You can get a NOS switch if you have a good part #, probably from Early Ford parts, or that place down in Waxahachie (NOSpartsltd.com) or maybe eBay.
This would be by far the best choice, as aftermarket electrical parts have long been a gamble, but especially these days with all the overseas crapola parts.
Old May 17, 2016 | 05:13 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The original switch (C3AZ-11572-A) was replaced in 1967 with another (C7UZ-11572-A) that has an extra terminal.
C3AZ-11572-A .. Ignition Switch (Motorcraft SW-353) / Obsolete
Misc. applications: 1961/66 F100/1100 / 1965/66 Mustang / 1966 Bronco.
This switch was available from auto parts stores, but by now, it's probably the 1967 replacement.
C3AZ-11572-A =
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
OBSOLETE RELIABLE PARTS in Nashville GA has 1 = 229-686-5101.
Old May 18, 2016 | 02:09 PM
candoo's Avatar
candoo
Many thanks ND.
Old May 19, 2016 | 11:45 AM
candoo's Avatar
candoo
Switch replaced with NAPA Echlin type. Old switch fell apart in my hands while trying to remove. Works perfect now...............WIN.
hest_c
Apr 9, 2018 06:29 PM
deansbuild
Sep 22, 2012 04:15 AM
michaelshewkin
Oct 19, 2010 11:07 AM
ftrain
Aug 13, 2002 10:28 AM
mikes66
Mar 4, 2001 01:25 PM
