1965 f100 switch r
Ignition switch? Do you have the tumblers out? If you do not, they come out first, turn key to the left and push a paper clip, or something like it in the hole. push the paper clip in and turn the key a bit more and they will come out. Then reach behind the switch and push the switch in and turn, bezel will unlock and come out the front.
Remove battery cable for safety before sticking your mitts behind the dash.
Switch is "spring loaded" has a coil spring on it. Bezel has two notches, attaches to two pins on switch.
Push switch forward from behind dash with one hand, gently turn the bezel 1/4 turn with the other.
There is a round spacer between the switch and the backside of the dash, it will probably fall off the switch once the bezel is removed.
C3TZ-11584-A Bezel is reproduced. Some peeps do not know how to remove it, use pliers and twist away. So, do not be surprised if notches are cracked or one has torn off.
which switch ?? ignition is as described above...if you are talking about the wiper switch with the pull for window washer, a thin bladed screwdriver or similar in the slot will depress the spring clip holding the know to the shaft...then unscrew the small retainer nut inside of the bezel with the 2 notches opposite of each other...I usually use a number zero Phillips in one side and as I try spinning it off counterclockwise jiggling the switch from behind.
- cs65
- cs65
DGMFORD
03-22-2022 12:30 PM
DGMFORD
03-24-2015 01:08 PM
Darren M.
01-01-2005 06:42 PM
