Has anyone here used Mevotech ball joints. Are they any good. If not what is a good choice????. Time to go through the front end and wanna make sure it's done right.
4wd, 2wd? There's some tips and things to look for when doing the 4wd. Mine also ended up taking an entire weekend, both 12+ hour days. I did mine at 260,000 miles however so take that with a grain of salt.
If 4wd, expect axle seals. You can make the tool yourself for about $20 from Lowe's and about 30 minutes (I only had an angle grinder so it took forever to cut the flange down).
Thank guys... Yes it's 4wd 221000 miles. I figured it would take some time. Hopefully not 2 days but if so... So be it. Will also have to look into this special tool so I can have it on deck lol.
In the sticky links up top of this forum there's a tech folder. I followed the second link for ball joints, and inside THAT there's a link to what you need for your own axle seal tool
There's also a pretty comprehensive list of part numbers for items that you may want to replace, such as the axle seals.
XRF are quality pieces. Once you do the first side, the second is much easier. I bought the seal tool. I don't have a good way to have pipe machined. I know it is right and worked super easy. I did the hub, ujoint, brakes all seals, steering linkage, redhead and brake lines. I am confident I could drive anywhere in the US I might need with just an oil change.
Everything on the front of my rig was still very tight, except the DS upper ball joint. I just did all ball joints and seals since I had to tear things down anyway - if you're gonna do one side, might as well hit both sides and do a complete job. The ball joints that were on it were Moog, so they had been replaced at some point. I liked what I'd read about the XRF pieces, so to me they were a no-brainer.
My front axle u-joints were in very good shape, as were the front drive shaft. The rear drive shaft... lets just say I have a little squeaky noise coming from under the truck every now and then. I have the joints, just have to find the time to swap them - really soon since I'm going to Maine in a month.
Found some XRF's on eBay so they're on the way. Yes definitely plan to do both sides. Guess I'll tackle this in next couple of weeks. Gotta get it done before summer trips start lol.
eBay is where I got mine - complete set for less than Autozone wanted for just one side.
If you don't have the removal/installation tools, rent them from Advance or Autozone. DO NOT buy the crap Harbor Freight sells. That crappy set slowed me down almost a whole day just trying to get them to work right...
Lol luckily I've never heard of Harbor Freight so Advance Auto will be the top choice. Thanks a lot of all the advice. I hope you can track down that high pitch squeal you're hearing on your truck,,,, wish I had some advice for you. I know what that's like. The struggle is very real.
FWIW, I used the harbor freight ball joint press, there were two to choose from and I got the bigger of the two, but I did have to make some custom spacers to get the joints seated all the way, and to press them on the correct location. I believe I used a few different sizes of outer races from other bearings and cut to create the spacers.
