A couple of months ago, Parts Guy Ed tried to find some greasable ball joints for my 2WD and couldn't. So, I have a set of non-greasable Motorcraft ball joints waiting to be installed.
XRF makes some, but if you have some Motorcrafts already paid for I wouldn't worry too much. The 2wd isn't nearly as hard on ball joints and the 4x4's seem to be.
Thanks Chris, I wondered about that. After sending PGE on a wild goose chase, I felt sorta obligated to buy the ball joints from him. I'll keep that in mind for next time.
Roland and I replace all four of my ball joints with greasable Moogs.
Not sure where everyone is getting their ball joints but i got mine at an oriley's here in Houston with the grease fittings. Might be worth ordering from them online?
I disagree. Some of the greasable stuff is great, but most of the time the non-greasable stuff isn't quite as bad as everyone makes it out to be.
Would you rather have wheel bearings you can actually service or do you like the sealed unit bearings on the front wheels that have to be replaced instead of just repacking them or changing a bearing and race?
It's not so much that aspect of the unit bearings that sucks.....
But the fact that the bearing races themselves are half the distance apart as the fixed-spindle counterparts. I HATE the idea of unit bearings in hubs...it is cheaper and faster for assembly (hence the reason they're used). On the flip side, how many people do you know that actually take the time to disassemble and repack their front wheel bearings (or trailer axle bearings for that matter)? But this discussion was about ball joints, not wheel bearings.
There's a reason that the factory u-joints and ball joints typically last so much longer than any greasable replacement you can get (and it's not because of crappy materials in the aftermarket stuff).
