Service Engine Soon Light
Old May 20, 2016 | 01:11 PM
  #46
RobRoss's Avatar
RobRoss
Originally Posted by Country_Mouse
What's PCM?
That is the "brain" the engine runs off of. It's possible the codes were caused by someone unplugging that particular sensor while the engine was running. Just keep an eye on it.
Old May 20, 2016 | 01:14 PM
  #47
Country_Mouse's Avatar
Country_Mouse
Where is the sensor that could of been unplugged? Maybe it's connected to the mystery red button...
Old May 20, 2016 | 01:15 PM
  #48
Country_Mouse
Our warranty is up in a few days so if we don't take care of it now will cost us 50% more in future.
Old May 20, 2016 | 01:18 PM
  #49
RobRoss's Avatar
RobRoss
It's plugged in now otherwise you'd have a MIL on. The speed sensor is at the back of the trans, at the top. Hard to say which code(s) turned on the MIL, some of the codes may have been present from before you bought the truck, that's all I'm saying.
Old May 20, 2016 | 02:06 PM
  #50
Country_Mouse
Okay, appreciate it Rob.
No one unplugged while running. Came on while I was driving it and we haven't messed under the hood at all except for battery a while back. Oh yeah and adding a quart of oil. Maybe it got bumped or something?
Dealer called. As of right now they are replacing a solenoid related to the 4x4 whatever that is. I recognize as it was one of codes.
Old May 20, 2016 | 02:40 PM
  #51
Vwags's Avatar
Vwags
Well you do have evidence that you brought it in for a concern prior to the warranty running out so if something similar shows itself shortly and the warranty expires you can at least make an argument.
Old May 20, 2016 | 02:54 PM
  #52
DidieX's Avatar
DidieX
When you replace the battery the codes usually get cleared. So the codes may or may not have been present when you purchased the truck. That should rule out someone unplugging a sensor if it hasn't been to a shop since changing the battery.
Also, I have p0500 code, it's related to the vss (vehicle speed sensor) circuit and a p1876 code. If I clear the computer it usually comes back within a month or two. I haven't noticed anything wrong with the 4x4 (shifts in and out of 4x4 and low range no problem) or anything else though. I'll have to track it down sometime. Might just be a loose connection.
Old May 20, 2016 | 08:21 PM
  #53
Country_Mouse
All Done. Picked up Ex. They replaced some solenoid, battery cables, and did "the works." (Oil, fluids, rotate tires.) Cost $240 total. Never pinointed about speed sensor code. They thought it could be related possibly to solenoid? Fingers crossed all is well now.
Old May 21, 2016 | 09:17 AM
  #54
projectSHO89's Avatar
projectSHO89
The PVH solenoid cannot cause those OSS/VSS codes. No connection to each other, electrically or logically.
OldParatrooper
6.7L Power Stroke Diesel
Dec 18, 2023 02:08 PM
Jerry Chaney
Nov 15, 2016 07:54 AM
TyWebb
Feb 10, 2011 08:54 PM
shlby123
Modular V10 (6.8l)
Feb 5, 2009 06:39 PM
cmcmana1
3.8 & 4.2L V6
Dec 17, 2006 05:32 PM
