metal chunks in diff housing
Old May 1, 2016 | 10:36 PM
justcruzin125's Avatar
justcruzin125
Hey i need some help guys. I have a 1990 f250 with a sterling 10.25 rear axle full float. I was draining the gear oil and was sweeping my finger in the little catch hole at the bottom in the inside of the housing. I pulled out what looked liked a roller bearing. But looking at bearings, they all looked fine and were larger than the one i pulled out. I then saw the top of the spider gear pin was shered off along with a hole. Do u think thats were the pin came from? And what would cause this kind of damage?
Old May 1, 2016 | 10:38 PM
justcruzin125
Here r the pics
Old May 2, 2016 | 01:31 PM
ifrythings's Avatar
ifrythings
Can you get more pics of the carrier, from what I can see it looks like the pinion was having some fun with the carrier, common for the early (pretty 1993) axles to get loose pinions.
Old May 2, 2016 | 01:41 PM
justcruzin125
That was the only damage to the carrier. I just dont know how a hole got into that pin. Shouldnt it be solid?
Old May 2, 2016 | 02:15 PM
ifrythings's Avatar
ifrythings
In your pic of the pin, just above it on the carrier looms like marks evenly spaced from each other that look like the pinion mite of hit it, I had a 8.8 that did that but didn't blow a chunk of the pins out but did break the bolt holding the pin in, made for a hell of a time to get out.
Old May 2, 2016 | 02:38 PM
justcruzin125
I took a look at the ring gear, no damage . as little as i can see of the pinion it seems to be alright in terms of damage. I know it needs to be fixed sooner vs later but do think it would still be drivable for a bit until i get a trutrac?
Old May 2, 2016 | 02:45 PM
ifrythings's Avatar
ifrythings
Check to see if the pinion is loose, if it is you can remove the nut, apply some loctite and tighten it back down to 160-180 ft-lbs and run it like that as a quick fix, to do it right you should replace the bearings and gears if they show wear or damage. As for the broken pin, you take a risk running it like that, it may stay in or it may fall out which will stop you instantly and destroy the diff.
Just my 2cents
Old May 2, 2016 | 03:04 PM
justcruzin125
Thanks man. Looks like im getting a detroit and overhaul kit sooner than expected
Old May 2, 2016 | 03:37 PM
ifrythings's Avatar
ifrythings
If I were in your shoes, I'd find another diff that's 93 or new and swap that in and save all the hassle and expense of changing gears (unless you were thinking ratio change) and if funding allowed get the Detroit locker and stick it in the new axle then put it under the truck, your going to spend at least 500 on bearings and gears just to fix this axle and you pick up a jy unit for 200 or less.
Just another option.
RojoStar
Aerostar
20
Mar 29, 2022 02:03 AM
DSLTRK60
Oct 29, 2019 03:43 PM
SideWinder4.9l
Apr 3, 2013 09:26 PM
75F350
Offroad & 4x4
35
Dec 6, 2008 02:40 PM
bigrey6306
Offroad & 4x4
Aug 22, 2008 05:36 PM
