Help I'm stuck
Old May 29, 2016 | 04:42 PM
  #46
JEFFFAFA's Avatar
JEFFFAFA
Originally Posted by 72CC428
So Orich, When I used the easy out it pulled out essentially what was a paper thin amount with the threads attached. But it came out in two segments and a third segment was still in the hole and I couldn't get the easy out to bite into this. I even tried the next size up in the set.
1st, sounds like you better tell the wife you're sorry. How far down the hole is the broken ez out? Can you reach the ez out with a punch and Light hammer? GENTLY hitting it side to side to try and get it to release?
Old May 29, 2016 | 07:05 PM
  #47
72CC428's Avatar
72CC428
Originally Posted by CougarJohn
I am sorry for the misunderstanding, pal. What I meant was that there is no thermal gradient across the housing, unlike a head or exhaust manifold. The seal is against radiator pressure. If you put some sealant on the gasket- and you have any threads engaging at all- you can gently snug up. If the spec is 20 ft-lbs, snug to 5 on the bad bolt. If it leaks, snug higher.
Get what thread you can get and go with it. Otherwise, you need a guy with an acetylene torch to burn. Risky stuff.
Semper Fi
Bad weekend for the vets
Thanks Cougar John. Yeah, bad Karma. I should have gone to church. Nothing bad has ever happened to me there!
When did you serve?
Thank you for your service. Hoist a mug for those who can't.
Old May 30, 2016 | 08:36 PM
  #48
72CC428's Avatar
72CC428
I'll give this a try. It basically in the bottom 1/3 of the hole. I thought about using a punch to try and "chip away" at it, but figured the punch tip is just as likely to break!
I feel like an idiot. I should have known not to "push" the tap. I should have backed it out once it didn't want to move anymore. As Charlie Brown would Say... Arrrgh, Good Grief!
Old May 30, 2016 | 11:00 PM
  #49
orich's Avatar
orich
Sorry you had to learn a hard lesson but you've learned a lot.
Now once you get a threads started then use a bottom tap. This won't have a pointed tip but flat bottom so you can tap into bottom of the hole.
If you can't get a lot of good threads may be think about putting in a stud to save the threads what's there.
Orich
Old May 31, 2016 | 02:42 AM
  #50
JEFFFAFA's Avatar
JEFFFAFA
Orich
2X. Good idea Rich.
DieHardChief
Dec 1, 2013 11:51 AM
302grabber
Jan 3, 2010 07:55 AM
pvatki
1983 - 2012 Ranger & B-Series
Sep 29, 2009 05:38 AM
tweakingit
Sep 29, 2003 07:34 PM
