Fuel Pump Pressure???
Old Feb 27, 2011 | 09:59 PM
landstorm's Avatar
landstorm
On another site, someone stated that the psi on the schrader valve when the engine being turned over should be 40 lbs. Does this sound right? Mine is 25.
Thanks
Old Feb 27, 2011 | 10:06 PM
Ken_C's Avatar
Ken_C
40psi at idle, cranking id say 25 isnt unheard of
Old Feb 28, 2011 | 10:13 AM
427 fordman's Avatar
427 fordman
I'd say that's pretty low
Old Feb 28, 2011 | 10:18 AM
landstorm's Avatar
landstorm
The 25 was on cranking only, not running.
Old Feb 28, 2011 | 10:24 AM
427 fordman
Are you having problems starting or have you checked it running?
Old Feb 28, 2011 | 03:01 PM
makomark's Avatar
makomark
The factory diagnostic chart says => 20 PSI at cranking RPM is acceptable.
The same reference also states 30-70 PSI on the road at WOT. I'm pretty sure most of us shoot for the higher end of this spec.
