fuel pressure
Old Aug 12, 2003 | 09:31 PM
anthony aiello's Avatar
anthony aiello
fuel pressure
hi does anyone who how much pressure ford designed the fuel switching valve to handle, or how much fuel pressure is used in a 1990 f150.
Old Aug 12, 2003 | 11:19 PM
Ford_Six's Avatar
Ford_Six
fuel pressure
Welcome to FTE!
The actual pressure used by the truck depends on the engine- The 300-6 used a little higher of pressure than the v-8's did. The in-tank pumps only make between 5 and 7 psi, so I wouldn't trust the valve with too much more than that. The system pressure at the rail is generally between 35 and 55psi.
Old Aug 13, 2003 | 09:45 PM
anthony aiello
fuel pressure
thanks for the info, does anyone know of a fuel switching valve that can handle 50 psi. I just built a 390 efi for my 76 f150 that is running about 45psi at the rail at full throttle. I would really like to keep both tanks working the way ford designed it to work.
Old Aug 14, 2003 | 01:41 AM
skidj0003's Avatar
skidj0003
fuel pressure
My 89 F-150 has a high pressure pump mounted on the frame that recieves fuel after it passes through the tank selector valve. I have measured running pressure of 58 psi at the fuel rail and one manual cites 50 to 60 psi as normal for the I-6 (less for other engines). At some point Ford stopped puting a high pressure pump on the frame. If Your truck does not have the high pressure pump, then it seems that the in tank pumps must pressurize the fuel and the switch valves probably can handle the pressure.
