Help please
Old Apr 18, 2016 | 08:07 PM
arielpink78's Avatar
arielpink78
Help please
My 2001 ford explorer has been broken down for three months. . Changed the fuel filter and changed the oil, and fluids..2hours after driving it won't start! I got the code p0230 but I can hear my fuel pump functioning. I checked the relay. I can't seem to figure it out. Pls help
Old Apr 18, 2016 | 09:15 PM
steve(ill)'s Avatar
steve(ill)
do you have fuel pressure at the fuel rail near the injectors ? My F150 has a Schrader valve on the fuel rail that you can press and should get a squirt of fuel out of it.
Old Apr 18, 2016 | 09:44 PM
shorod's Avatar
shorod
The P0230 can be either due to a short to ground or a short to battery power. You mention you hear the fuel pump functioning. Do you ever hear it shut off? When the ignition key is first turned to Run you should hear the fuel pump run for about 1 second, then shut off.
-Rod
Old Apr 18, 2016 | 10:54 PM
arielpink78
I hear it for about one or two seconds then it stops... I have released pressure by doing that as well.
Old Apr 19, 2016 | 06:46 AM
shorod's Avatar
shorod
Which engine does your Explorer have? You mentioned after 2 hours of driving it won't start. Does the starter spin the engine over it just never starts, or does the starter not even spin the engine? After it cools down will it start?
-Rod
Old Apr 19, 2016 | 09:26 AM
arielpink78
It was driving fine, went go drive to the store and it died at the end of the driveway. Has not started since. Everything under the hood looks great and works great. It's just not starting. I have enough spark and I have enough power but it doesn't start
Old Apr 19, 2016 | 12:49 PM
steve(ill)'s Avatar
steve(ill)
if you have fuel and you have spark, it will start if the timing is right.....If your sure the injectors are working, then timing is off...... Maybe put a shot of ether into the intake and see if it trys to fire and start. If not, that will confirm that fuel is not the problem.
Old Apr 19, 2016 | 06:00 PM
arielpink78
I don't think there is enough pressure coming from the pump.
duphofff
1997 - 2003 F150
Aug 20, 2018 04:28 PM
Race4Fun82
Jan 21, 2014 08:42 PM
matt2fan
Jul 10, 2012 03:13 PM
thefordlane
1983 - 2012 Ranger & B-Series
May 5, 2010 07:05 PM
rockdawg84
Apr 20, 2007 03:05 AM
