Fuel pump problems
Old Apr 10, 2016 | 09:58 PM
Adamristeen's Avatar
Adamristeen
Fuel pump problems
I've owned my 89 f250 with the 7.3 in it for 3 years now and in that time I've had to change the injection pump in it twice already and it's on it's way out again. Been buying new rebuilt pumps and they haven't even been lasting a year. The issue I'm having right now with it is it will fire up decent when cold but will barely fire when it's hot. If I shut it off for 5 mins or even just to order my coffee it has trouble starting. I've changed the lift pump on the engine and put new fuel lines and tank on. Would like to find the cause of the pump failures...
Old Apr 10, 2016 | 10:05 PM
Macrobb's Avatar
Macrobb
Where are you buying them from? Cheap crummy rebuilds is one thing we see a lot around here.
There are only about three places that are recommended around here for pumps, one of which is R&D IDI Performance - R&D IDI Performance - Home
One test you can do is get the engine warmed up, let it sit for 5-10 minutes for it to "heat soak", then pour cool water over the back of the IP(where the injector lines come from). If it fires right up, it's head-rotor clearance that is the problem; typical of this sort of failure.
The real problem is that the replacement cost of the head and rotor set is somewhere around $400 in parts alone, so cheap rebuilders aren't going to replace it, even if it is needed.
A bad starter can cause issues as well, but the failure mode is usually hard/no starting when cold. Once it's warmed up, the batteries are better charged and everything is easier to move.
Old Apr 11, 2016 | 02:47 PM
Leroy Unlisted's Avatar
Leroy Unlisted
yea get a good pump to begin with ..
and run 2cycle oil or atf plus powerservice if your fuel to keep it lubed or it will wear out ..
Old Apr 13, 2016 | 11:17 PM
speedwrench72's Avatar
speedwrench72
Leroy the myth that ULSD is not lubed is just that a myth.. all diesel has a lube added and will not wear out the IP...ALL.. the problem is prolly a bad IP or AIR in the system.. or glow plug controller..
Old Apr 14, 2016 | 02:38 AM
Leroy Unlisted
fact or fiction there is one thing of which i am sure ...
ATF and 2cycle oil will add lubricity to the fuel ..
you can debate whether that the extra lubrication is necessary or not ..
i will not argue that .. because it's your motor .. your call
i do know that the IP is cooled and lubed by the fuel flowing through it ..
and i would like the fuel flowing through my IP to be extra slippery ..
my IP looks original oem .. no problems ..
only had to replace one injector that was bad when i bought the truck ..
just runs great .. 2c
Old Apr 14, 2016 | 07:25 PM
tankguy's Avatar
tankguy
I have a customer this morning inquiring about his HPFP.
www.integritylubricants.com/ulsd-diesel-fuel-problems
mark460
Mar 7, 2018 11:57 AM
dioxippus
Nov 17, 2016 07:58 PM
jmuenchow
30
Oct 6, 2015 08:59 PM
a711112a
Aug 28, 2009 09:09 PM
blameitontexas
Sep 10, 2003 08:24 PM
