Replacement tv antenna?
Old Apr 21, 2016 | 07:39 AM
  #31
superrangerman2002's Avatar
superrangerman2002
Originally Posted by RV_Tech
That's the one I'm planning on getting.
Old Apr 21, 2016 | 07:41 AM
  #32
RV_Tech's Avatar
RV_Tech
There are others that are a good deal cheaper, but without as many features,
Steve
Old Apr 21, 2016 | 08:49 AM
  #33
wrvond's Avatar
wrvond
I've apparently lost my mind. Yes, that's the one.
Old May 8, 2016 | 05:05 PM
  #34
superrangerman2002
Well you guys were right! I replaced the amp and it works WAY better. Having the audible sound makes it a cinch to orient as well!
Now I just have to get the antenna orientation pointer re aligned with actual.
Old May 9, 2016 | 09:19 AM
  #35
wrvond's Avatar
wrvond
That pointer isn't aligned with any particular direction the antenna is pointing. That is to say, aligning the pointer with the stationary pointer simply orients the antenna so that it will lay flat on the roof and not hit anything.
So when you do align the two arrows, make sure your antenna is in the stowed position.
Old May 9, 2016 | 01:15 PM
  #36
superrangerman2002
This is what I was referring too.
Thanks
ivory-tower
Aug 20, 2011 10:10 AM
Aftrmidnite
General Automotive Discussion
Jul 19, 2010 12:14 PM
cc_rider
Aug 14, 2006 09:04 PM
Jupiter Coyote
1997 - 2003 F150
Apr 20, 2004 01:54 PM
b_berkeley
1978 - 1996 Big Bronco
Feb 21, 2003 10:33 AM
