Fuel theft
Disclaimer: Of course I am joking. I would never premeditate deadly force. Stopping force, yes. Deadly is the unfortunate side of confrontation, a risk with us every day.
Now man-eating crocodiles...they have a mind of their own!
Spectre 6008B, Spectre Steel Braided Hose Sleeve | Spectre
Another option might be a custom length SS braided radiator hose. I'm not sure of the fill tube diameter on our trucks, though. The braided radiator hoses I've seen are typically 1-1/2" diameter.
http://www.summitracing.com/parts/sp...FdcagQod_rwAVg
As mentioned already, though, once you've secured the filler tube, your fuel lines and tank then become the next potentially vulnerable targets.
Chances are it is one person stealing the fuel and when he can afford to fix his fuel system he won't need any more fuel.
Never met a thief who could suck gas with broken ribs.
I had a stereo jacked out of my jeep about 20 years ago and they did so much damage I needed another vehicle so I got a blazer while the jeep was put back together by insurance. In getting to that point in life (doing higher end system designing and installs), I'd had several talks with the police about anti-theft measures and what was too far - "can't deliberately harm them." OK.
So when I needed to enlarge the opening in the dash of my K5 blazer; I was, shall we say, Crude.
I used tin snips, bent the jagged steel back at 90 degrees to form twisted razor blades with nice pointy tips that were parallel to the radio sleeve. You could remove the deck without harm, but the sleeve would bite you if you weren't aware of how it was framed in punji spikes around it.Well, the new deck was only in the blazer for about 2 weeks when it got stolen. Blood everywhere!
Should have been more careful, oh well at least it was easy to clean up I hope...I mean really who would be rude and leave blood in another mans car....
(Gee I hope this doesn't show how cynical and hateful towards thief's I can get...
It was a $100 deck when $100 didn't buy you much. They did $900 in damage getting it.The blood cleaned up easy. The previous owner must've scotch guarded it or something. It was on the front seat, back seat, armrest, door panel, and floor carpet in the front and back. Did I mention I got them good?
Cops said I couldn't put razor blades in there because that's intent to harm. Well, if you're not supposed to have your hands in my dash, why does it matter if I put razor blades in it? My having nice stuff is not an invitation to steal it. There's no compulsive urge to break into a car like there might be for a kid to jump in a swimming pool. The cops tried saying I had an attractive nuisance because I had a nice jeep. Think that'd fly if I broke into some mansion and said "It was just so inviting looking compared to my house - I let myself in!" Heck no...
Razor blades? I thought they were called "shims" LOL.
My jeep had 5K in stereo gear in it and they slashed the seats and door panels when they figured out I made things VERY difficult to remove and ended up breaking the valuables when trying to pry them out. See, I used welding tabs instead of screws, and all the amps were bolted to a chunk of 3/4" MDF that was sandwiched between the floor and the rear seat hold-down brackets (4 torx bolts held those in and they were rather large - probably T50ish so no smash and grabber is going to have one. On the underside with the nuts, I had big fender washers and then used silicone to prevent the nuts from spinning independent of the washer. Were I ever to need to remove those amps, I'd grind the nuts out from below. As it happened, the thieves popped the screw heads off the back of the amps (the ones holding the heatsinks to the chassis), so you know they weren't worth anything with all the damage from prying them up.
I had a rider on my policy for all that gear, but they didn't want to pay it until I threatened to sue them 4 months after the fact. The thieves got pissy and cut all the wiring under the dash when they couldn't figure out my anti-hotwiring relays. See, instead of a NC relay that the alarm opens with 12v when activated, my starter was on a NO relay that needed 12v with the key. Dead simple arrangement, but thieves see those relays and think "Snip!" From then on, you have no wire going to the starter solenoid even though they think they closed the circuit. Good luck buddy!
http://www.dahuasecurity.com/en/us/
