Did your check engine light come on? Mine did about a month ago. I forget the code it showed. But it was a sensor on top of the trans. Light just came on again doing the same thing. Need to take it back in and get them to warranty the part. My O/D light was flashing off & on at start up and slow moving. When up to some speed it went away.
My O/D Light flash some times, no codes thrown. What could cause it?
There are at least 50 things that could cause this. There IS a code in the computer. You need a better reader to find it. Without the code NOBODY knows what's wrong.
Well Mark, You HAVE narrowed it down Good to hear from you. Do you have a scanner attached to FTE that alerts you to any & all transmission questions ?? LOL
I use AutoEnginuity, but since you don't have AE and you can't find anyone with a code reader that reads trans codes, I suggest you pay a reputable transmission shop to read them for you.
