Wrench light
Old Jul 7, 2011 | 12:34 PM
broncos5332's Avatar
broncos5332
Wrench light
My wrench light comes on after 20mins of highway driving. It doesnt come on when driving in the city. I have used my scanner and it shows no codes. The truck drives just fine when the light comes on. No loss of power or limp mode. Any suggestions on whats causing this? Thanks
Old Jul 7, 2011 | 12:56 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Does the light go back out while you are driving? It is possible that your scanner won't pick up some codes..... go to an Auto Zone and have them test it...it's a free service.
Old Jul 7, 2011 | 01:09 PM
broncos5332
The light stays on while driving. When i shut it off and start it back up the light is gone. I will give that a shot. Thanks
Old Jul 7, 2011 | 01:40 PM
texans's Avatar
texans
The autozone tester are very good either. What are you using to check for codes? You might need more than a generic code reader.
Old Jul 7, 2011 | 01:56 PM
broncos5332
Its a innova digital can obd2 scanner. I bought it from oreilly auto parts last year. Its a pretty generic scanner. I have heard that the auto zone scanners wont pick up the code but its worth a shot to try. Thanks
Old Jul 7, 2011 | 03:21 PM
onuredneck707's Avatar
onuredneck707
Same thing happened to me a few weeks ago, although once I shut it off and turned it back on, the wrench has not been back. I bought a Scangauge II to monitor my ECT vs. EOT and I think my oil cooler is the culprit. Keep us posted if you find out something else is causing the problem.
Old Jul 7, 2011 | 03:23 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
If you have the innova CAN version, it should pull all the codes.....mine does! Mine is the Model 3130
Old Jul 7, 2011 | 03:34 PM
Mich6.0's Avatar
Mich6.0
eot ect programing per the flash >15deg spred ?
Old Jul 7, 2011 | 03:37 PM
broncos5332
I have the 3100. I read the codes with the key turned but not the engine running. Could that be the problem? I dont think mine reads the ECT or EOT. I have heard that it could be the acceleration pedal sensor/throttle control unit or the oil cooler. Im just at a loss of what it could be. Thanks for all the help guys!!!
Old Jul 7, 2011 | 07:04 PM
cheezit's Avatar
cheezit
not all code reads will pull all codes.
Old Jul 7, 2011 | 07:36 PM
ilcowman's Avatar
ilcowman
I had mine do the same thing when I was passing a car think it was from turbo overboost but no codes and I use the sgll
Old Jul 7, 2011 | 07:50 PM
98SurplusExpy's Avatar
98SurplusExpy
Sounds like a oil cooler replacement is in your future.
Also ... AutoZone scanners will not pick up wrench light codes, you'll need to go to the dealer or get something like an Edge Insight CS.
Old Jul 7, 2011 | 10:26 PM
broncos5332
Yeah i think its the oil cooler also. When the light comes on it doesnt lose power or go into limp mode so i think its not the turbo. I guess im gonna have to break down and take it in. Thanks for the help!
Old Jul 8, 2011 | 01:21 PM
Carolina Rig's Avatar
Carolina Rig
I 3rd the oil cooler diagnosis. Mine wrench light came on last year driving on the interstate. As I recall, a short drive wouldn't turn it on. But it was the oil cooler efficiency.
I replaced the oil cooler and it never came back on.
If you do it yourself, you may consider doing an EGR delete and having your intake manifold flushed, since it's all gonna be sitting out on your workbench anyway.
Replace the screen under the oil cooler while your in there.
I'd recommend flushing the cooling system with VC-9 thereafter. There's a good procedure detailed here at FTE by "beachbumcook".
After that, you should be G-to-G (good to go).
C-Rig
ryanbodden2014
6.4L Power Stroke Diesel
36
Jan 30, 2015 06:24 PM
twheatii
2004 - 2008 F150
Dec 12, 2014 10:28 PM
bcollison98
Jul 21, 2013 06:53 AM
my6.4Lsucks
Jul 30, 2011 06:06 AM
STX04
2004 - 2008 F150
Jul 28, 2008 09:54 AM
