PS Shaft Bushing Condition?
Old Apr 1, 2016 | 09:22 PM
chukar's Avatar
chukar
The is the Ford/Thompson type PS pump.
The shaft as you can see is not bad even though it looks not so pristine. But the shaft bushing is gouged, but having no experience don't know if I need to replace it, and where to find the part if I do. I'm surprised at the difference in the condition between the shaft and the bushing but I suppose that's the reason for the bushing in the first place. So, what do you think? Thanks again. Vic
Old Apr 2, 2016 | 03:36 AM
mark a.'s Avatar
mark a.
Remans are cheep enough that it probably isn't going to be worth messing with it. Unless someone makes a rebuild kit it's hard enough to find hydraulic oil seals and you are going to need a front seal. When the pump was engineered the seal was likely too. It is the probably the mfgrs seal design, not just a run of the mill say 1/2 x 3/4 seal. No, it will be some odd ball making it next to impossible if not impossible to find. It's hard enough to find anyone who sells hydraulic oil seals but adding in that it's measurements are not standard save yourself the grief and just get a new one. I've been through this and Cardone will be of no help + they are always "jerks" on the phone making your bad situation worse by the time they "hang up" on you.
Old Apr 2, 2016 | 08:14 AM
ultraranger's Avatar
ultraranger
Agreed on getting a rebuilt PS pump for simplicity and expediency. They are only around $40 bucks and it will come with a warranty. If you can rebuild your existing pump, you don't get a warranty.
Once you put the pump back on, prime it BEFORE you put the belt on and crank the engine. Engine idle speed is much higher than the priming speed of a variable speed drill. Cavitation (air) in the pump/PS system can easily burn the pump up or damage it before the pump gets completely submerged in fluid. A damaged PS pump will have a constant and noticeable whine to it.
Photo of my angle drill and a 3/8" hex bit engaged into the hex on the front of the Ford C-2 PS pump on my truck, when I was priming the system prior to putting the belt on and before I ever cranked the engine. My PS system was quite from day one and has never whined.
Old Apr 2, 2016 | 08:23 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Ford didn't sell the bushing as a separate part, you have to buy the front plate to get it. They also had a seal and gasket set that includes all the seals and gaskets needed.
D1AZ-3B584-A Seal and gasket kit
D3AZ-3D643-A Plate and bushing assy.
Klimesh Motor Sales, Calmar, IA has one of each part (563) 562-3241
Dennis Carpenter, Concord, NC has 25 of the seal kits (704) 786-8139
Green Sales, Cincinnati, OH has 7 of the plate and bushing assys. (800) 543-4959
Hit Man X
Mar 27, 2018 11:59 PM
rlebar
17
Sep 10, 2014 07:55 PM
steelhead2
Mar 29, 2014 01:06 PM
briancooper
Jan 25, 2012 09:32 AM
mchild
Feb 4, 2003 05:57 PM
