HPOP servicing
Old Mar 3, 2011 | 07:01 PM
briancooper's Avatar
briancooper
HPOP servicing
Air test showed air loss at pump shaft seal. after inspection the seal isn't even in the casting its spining on the shaft. Is this seal replaceable or should i buy new HPOP?
When i fill with oil and place my finger over the discharge i cant spin pump by hand.
Old Mar 3, 2011 | 07:03 PM
briancooper
2003 f350 6.0 55k miles
Old Mar 3, 2011 | 07:14 PM
cheezit's Avatar
cheezit
sorry but you need a pump.
Old Mar 3, 2011 | 07:40 PM
briancooper
thanks i figured. hi ho hi ho off to ford i go
Old Mar 4, 2011 | 08:07 PM
smokersteve's Avatar
smokersteve
wait!!!! get the international and motorcraft part numbers( I dont know it ) for the hpop before you go to ford. It might be ALLOT cheaper online including shipping...
smokersteve
why did if fail at 55,000 miles?
Old Mar 5, 2011 | 05:55 AM
npccpartsman's Avatar
npccpartsman
Because the seal came out of the pump and is a nonservicable part.
Old Mar 5, 2011 | 07:45 AM
bismic's Avatar
bismic
2003 / 2004 HPOP...............3C3Z-9A543-AARM..........5010106R93
2005 / 2006 / 2007 HPOP......4C3Z-9A543-AARM................5010119R92
Old Mar 5, 2011 | 08:25 AM
briancooper
List at local ford is $669 my cost $560 with 1 year waranty. cheapist i had found was allmost $900
Old Mar 5, 2011 | 08:28 AM
briancooper
If it wasnt soo hard to get to i would peck the seal in and try but it took me 4 hours to remove (part of that was finding a way to plug discharge line to air test system without pump on. Two pieces of rubber and a c-clamp helt to 100 psi.)
Old Mar 5, 2011 | 08:39 AM
npccpartsman
The seal didn't just come out by itself. It came out for a reason. Defective seal, defective housing, internal case pressure (rare), who knows....... At this point you're better off going with a new pump. If you repair the old pump and it fails again you've wasted a lot of time and money twice, not to mention the fact that you can do some PM while you have the top off the motor.
Old Mar 5, 2011 | 08:46 AM
bismic's Avatar
bismic
$500 at TousleyFordParts
Old Mar 5, 2011 | 08:26 PM
briancooper
Thanks guys for advice and help.
Old Jan 24, 2012 | 08:37 PM
Dunnrightmobile's Avatar
Dunnrightmobile
@ brian cooper. What did u end up doing i am having the same problem
Old Jan 24, 2012 | 11:45 PM
matty169's Avatar
matty169
HPOP
I have a good used one if you want it cheap. 23k miles, 2003
