Sponsored by: Real Truck
4R100 Hard Shift
Old Dec 11, 2013 | 08:40 PM
da X-man's Avatar
da X-man
4R100 Hard Shift
It's been a while since I last been on here, but I have an issue I can't quite figure out and none of my searches seem to apply.
I have a hard shift between 2-3 that is somewhat violent. It doesn't matter the rpms or how hard I'm accelerating, it will always do it. At wot, it sometimes throws a code that stays on for a few minutes, then goes away. When I hook up a code reader, it shows no record of it and it never throws a blinking OD light ever.
It has an ATS transmission, but I don't know how the controller works, if it is wired correctly, or if it could even cause this issue.
Any ideas or other details you all need? Currently the truck has 210k and unknown on ATS.
Old Dec 12, 2013 | 07:35 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
How do you know it throws a code? The way the Ford controller works when a code is thrown the OD light flashes. No flashing, no codes.
Old Dec 12, 2013 | 07:52 PM
da X-man's Avatar
da X-man
The check engine light sometimes comes on when I really get in it and it shifts hard, but when I go to read what engine code it threw, it has no record of it. Since it isn't flashing the OD light, it tells me it isn't a trans code being thrown, but the truck still notices that something isn't right.
After doing some research, the ATS controller (when on) is only supposed to change the torque converter clutch lock-up based on MPH. However, I haven't noticed a difference in the shifting when it is on vs when it is off.
02f550
May 15, 2014 08:47 PM
wshrace27
Jun 8, 2011 02:00 PM
j tate
Jun 6, 2008 09:20 PM
bean440
Feb 4, 2006 04:19 PM
Ed the outdoorman
Aug 5, 2004 01:40 PM
