hard shifting
Old May 10, 2004 | 12:37 AM
happy camper's Avatar
happy camper
Unhappy hard shifting
I have a 1994 f-150 4x4 I recntly went camping towing our tent trailer. after arriving at our campsite we noticed that the truck started shifting quite hard into 2nd mainly but also into drive . almost shakes you out of your seat.I have not been using overdrive while towing. I have been reading about ford having problems with the mlp sensor causing problems.Is this where I start?? help please. tranny oil does not look or smell burnt.
Old May 10, 2004 | 07:36 AM
Cfidave's Avatar
Cfidave
Mine does the same thing. Took it to a transmision shop. They read the stored codes. It was not the sensor. It is the torque converter slipping ( code 684, I think) The slaming into gear is the computer going into failure mode, to actually protect the transmision. I am told five slips of the clutch triggers the protect mode, and issues the code. I am looking at a new heavy duty torque converter. It is possible that it is the sensor, the OBD1 code will tell you.
Old May 10, 2004 | 10:29 AM
happy camper
thanks for the info I am not going to drive it untill I can get it into a shop or get my buddy at work to bring in his scanner and check the codes .
Old May 10, 2004 | 03:18 PM
Cfidave's Avatar
Cfidave
Driving it won't damage it. It is 1n protect mode until either 1) the battery is disconnected or 2) the code is cleared.
Old May 11, 2004 | 03:02 AM
happy camper
I understand what you are saying just that in my opinion somthing that sounds that bad can't be good. I have an appointment at ford on thurs for some diagnostics I'll let you know how i make out. thanks again. besides at a buck a litre its better off in the driveway lol
Old May 11, 2004 | 12:03 PM
jim henderson's Avatar
jim henderson
Does your tranny have torque shudder? Torque shudder is when the truck kind of vibrates or rumbles like it is going over grooved pavement. This happens at about 50mph under very light acceleration. It goes away if you stop accelerating or under hard acceleration because the torque converter lockup clutch unlocks under those conditions.
The hard shifting can be a symptom of particles in the oil, or like the other guy said, the tranny is boosting pressure to protect itself. Either way, if you have torque shudder along with the hard shifting, things are going down hill. Pre 95 E4OD trannies had this problem and it was mostly due to a weak torque converter.
If it is shudder, eventually there will be damage requiring a rebuild. Better to get it taken care of sooner rather than later.
Good Luck,
Jim Henderson
Old May 11, 2004 | 12:58 PM
happy camper
I can't say that I have noticed that before. but I will keep an eye out for it.
Old May 13, 2004 | 02:18 PM
happy camper
apparantly clutch fan is hooped. and is not cooling the tranny enough this is sending the tranny into the protect mode . once I replace the clutch fan this should take care of the problem.this makes me wonder if I should also consider putting in an extra tranny cooler.
Ceaumar
Mar 8, 2019 09:37 PM
3cv
Sep 4, 2016 09:07 AM
deputydog03
Mar 16, 2016 09:42 AM
deputydog03
31
Mar 8, 2016 09:15 PM
LowlifeLLT
May 10, 2015 08:51 PM
