Harsh shift
Old Mar 31, 2016 | 08:45 AM
48f1builder's Avatar
48f1builder
Harsh shift
Hi all, My 94 F-150 4x4 5.8 auto, intermittently shifts very hard, it snaps your head back, other times it shifts perfectly. Anyone else have this problem? Thanks, Al
Old Mar 31, 2016 | 10:20 AM
Conanski's Avatar
Conanski
Have you noticed any issue with the speedo or ODO that may or may not correspond with the hard shifting?
Your PCM is detecting a sensor issue, the most common ones that produce hard shifts are with the TPS or VSS, so pull codes and post up what you get.
Old Mar 31, 2016 | 04:52 PM
48f1builder
I get a 62 code. as far as I can tell it the only one.
Old Mar 31, 2016 | 05:10 PM
Conanski's Avatar
Conanski
Code 62 is excessive converter clutch slippage, from what I have seen on here that most likely means you need to replace the torque converter, that code would certainly put the PCM into protect mode which is what produces the harsh shifts.
Old Mar 31, 2016 | 06:05 PM
rla2005's Avatar
rla2005
A 1994 model year truck should have three digit codes. How did you pull your codes? Code reader or count flashes?
There are exceptions but three digit codes are the norm.
Old Apr 1, 2016 | 10:11 AM
subford's Avatar
subford
X2^^^
The only 2 digit codes in 1994 were for the 4.9L with a standard transmission.
Also the DTCS 62, 628 AND/OR 1728 STORED IN MEMORY (CM) are covered in the TSB 98-4-19.
http://www.thedieselstop.com/faq/949...les/980419.pdf
Old Apr 1, 2016 | 10:41 PM
48f1builder
I counted the flashes
Deep_six_mechanic
21
Oct 30, 2017 07:02 PM
da X-man
Dec 12, 2013 07:52 PM
ssquints999
Feb 1, 2009 07:30 PM
Silentst2000
Jul 27, 2006 07:05 AM
happy camper
May 13, 2004 02:18 PM
