What is best aftermarket windshield wiper setup?
Old 03-22-2016, 06:42 PM
oscajo's Avatar
oscajo
oscajo is offline
Ready to do windshield wipers. Do not have any stock parts and am looking for easiest way to have dependable wipers. Thanks for any help.
Old 03-23-2016, 06:49 AM
mike.rogers's Avatar
mike.rogers
mike.rogers is offline
I'm working on one now. Billit style with cable. If it gets much "louder" then I'm going to pull it and go another route. Installation was fairly easy with hardest part deciding where to put the motor. The transmissions are a little tricky and I had to grind and modify the passenger side to make it set at the same angle as the driver side. Still working on making the original bezel fit and look good without modifying and ordering aftermarket ones
There is an aftermarket one made by raingear thats around $500. It looks to be a fit in, but it sure is pricey.
There are a couple good threads about this topic. You may want to do a search on it.
Old 03-23-2016, 07:17 AM
oscajo's Avatar
oscajo
oscajo is offline
I bought a kit off of Ebay, but the square flanges at the bottom of the posts holding the wipers interfere with some bracing under dash. Wanted a true bolt in that hopefully is quiet. Not really liking the one I bought.
Old 03-24-2016, 06:48 AM
artscott61's Avatar
artscott61
artscott61 is offline
How about the wiper arms it seems that they are all cheaply built. Do any of these kits come with a good strong arm or do we just live with it ?
Old 03-24-2016, 08:07 AM
oscajo's Avatar
oscajo
oscajo is offline
Kit I bought doesn`t come with the wipers.
Old 03-24-2016, 09:27 AM
fbb1951's Avatar
fbb1951
fbb1951 is offline
Specialty Power Windows I used Specialty Power Windows wipers on my '51 F1 They worked out nice.
Old 03-24-2016, 10:01 AM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
Since you asked for the "best", here ya go...Home | RainGear Wiper Systems
I have this system on my 56 and have previously used them on my 53. This wiper system is designed specifically for your model truck and is not an adaptation from any other vehicle. Not cheap but definitely the best IMO.
Old 03-24-2016, 01:05 PM
Nicholas+'s Avatar
Nicholas+
Nicholas+ is offline
I just got my Rain Gear kit last week. It is very high quality. It is pricey, but I wouldn't call it over priced. Not sure if they make it for your year though.
Old 03-24-2016, 01:33 PM
Jules The Great's Avatar
Jules The Great
Jules The Great is offline
I just recently upgraded mine to newer wiper arms with a stronger spring to hold the blade against the windshield. I sawed off the drive ***** from a bronco II bored them to fit over the 1/4" shaft hammered them on and used a set screw. Now it holds the blades against the windshield perfectly and is a pleasure to drive in the rain, vs a HORROR like it was before.
To answer the OP I am going to look at another bronco II and see if the system is adaptable as I do not think the 1/4 shaft is going to last forever.
Old 03-26-2016, 01:03 PM
lm987's Avatar
lm987
lm987 is offline
Wiper Motor
I bought mine from Speedway (~$150) if I remember right. It fit well but you had to use the original transmission and defroster outlets. A little tricky getting it in but it works great.
Old 03-26-2016, 04:23 PM
ChuckRob's Avatar
ChuckRob
ChuckRob is offline
I also used the Speedway kit and it seems to work fine, However, I live in AZ and the truck has only seen rain twice since it's been on the road.
Old 03-26-2016, 05:04 PM
Flat Ernie's Avatar
Flat Ernie
Flat Ernie is offline
I just put a later motor in my stock assembly. Got 2 speeds, self parking, and 12V...pretty straight forward. An aftermarket delay would be nice...
I've adapted Lucas wipers to work - they're very similar to those pictured - they're cable operated. The last set I tried I kept having issues with, but I've had success wit them before, so I would recommend them again.
Old 03-27-2016, 07:02 AM
Oz52F1's Avatar
Oz52F1
Oz52F1 is offline
Yes...the cable driven ones are all based on 60s/70s British Lucas units.
One more thing to pull from that Jag donor car.
Amazingly, new parts are available, (eg cable boxes, motors, and event shaft nuts in chrome). The cable box and shaft come up through the original cowl holes, the Ford bezels then seal it to the cowl, the new British nut then tightens it all together, then the Ford wiper arms happen to fit onto the British shaft perfectly!!!!
I'm running mine via a 70s LTD wiper switch to get multi speed intermittent and push screen wash too!!
BigNiner19
2004 - 2008 F150
39
06-22-2020 09:15 AM
1950flatbed
12-22-2016 09:33 PM
chetspencer
11-01-2016 07:28 AM
dawolverine
04-24-2009 07:05 AM
Redmanbob
10-13-2007 02:13 AM
Quick Reply: What is best aftermarket windshield wiper setup?
