I'm looking at the options for windscreen wipers at the moment - my truck has nothing at all currently.
If anyone can share good/bad experiences, ease of installation, fit, installed pics etc of any kits available that would be very helpful.
I got my kit from Carpenters and it was easy to install. I definately had to have electric wipers with 2 instead of one. I guess whoever bought this truck could not see the extra 8 or so dollars for the optional second wiper.
I have not purchased the setup yet but I am planning on going with the SPW cable setup on my F-1. If you want AC I believe that there will be a problem using aftermarket setup in mytbtruck's post above. The popular setup takes a lot of underdash space.
I stayed with the single wiper kit from sac vintage ford, and even if it cost an additional 8 bucks, I don't plan on running in the rain anyway.......have yet to do install.
I have already installed the a/c and the only problem was the defrost duct fittings. I changed the angle on them by cutting them in half and reversing the bottom half and used pvc glue to put them together. After that they cleared everything without a problem. I will get a picture under the dash when I finish with it. I need to get one more piece of flexible duct to hook up the defrosters.
I am surprised that you didn't have more difficulty. With my heat/AC setup If I used the wiper kit that you used I would have had to lose all of the glovebox. I did not buy one of the popular AC setups and assembled my own with flea market parts. Pix in my gallery should demonstrate what I am referring to. Whose AC did you buy?
My old truck has pneumatic wipers, so I rely on Rain X. As long as I keep it fresh, I do not worry about getting caught in a storm. I wouldn't even turn on the wipers except for the comic value of seeing them slowly struggle to clear the windscreen.
I Used Hot Rod Air a/c and I did lose most of the glove box. I am planning on mounting a radio/cd player in the glove box so it is not a problem. I think all the a/c units take out most of the glove box, don't know this for sure though. I tried to in put a glove box from Carpenters and did not like the way it fit so I decided to forget about a glove box.
I used the SPW kit and it is very adaptable. I mounted the motor in the drivers kickpanel. It works great, if I ever do need it I'll have it. I don't have any wiper blades installed for local cruising.
I also used the Newport Engineering system on my 51 - which had the Extra Cab electric wipers originally. I got it with the delay wiper switch and they work fantastic.
Here is the link to Newport Engineering if you want to window shop a bit:
Well, with my '53, I changed the vacuum wipers to electric by getting a 6V electric setup, (optional on 53-55s) then using a 12V motor which only required making up a new output arm from the 6V and 12V arms. I use an aftermarket intermittent wiper control with it. I am not going to use any A/C in my truck that would go under the dash or I would have to use different wipers and lose the glove compartment. Since I will not give up the cowl vent or the wind wings or the glove box, I am thinking that I will go without A/C entirely. I tried an old fashioned window cooler last summer and it worked outstandingly well. (I am not in a humid climate). If I do go with A/C, it will be similar to the Cherokee/Wagoneer setups below the dash. As far as a radio goes, it is a AM/FM/CD combo mounted up high in a console fashion. Speakers are in the doors. I have a vacuum wiper set for 53-55 and one for a 56 less the 12V motor very cheap. (See the classifieds)
