98 expedition p1747
Old Mar 22, 2016 | 04:27 PM
ephexpi's Avatar
ephexpi
98 expedition p1747
i have a 98 expedition 4.6 4x4 check engine light on od light flashing sometimes checked it and got p1747 code i was told epc solenoid or short on trans wiring. i already dropped the trans pan can somebody tell me a step by step easy way to diagnose and find the short or if i need to replace any of the solenoids i have voltmeter and taste light
Old Mar 22, 2016 | 10:13 PM
jk080's Avatar
jk080
Transmission Rebuilder
I cant give you a step by step on finding a short or a wiring issue but I do find bad PCM's in these when I get that code, just something else to check.
Old Mar 23, 2016 | 12:20 AM
ephexpi's Avatar
ephexpi
how do you check if pcm is bad
Old Aug 17, 2016 | 12:10 AM
Jhuntley's Avatar
Jhuntley
P1747
Any solution on this issue? I am having the same problem. The EPC solenoid has been replaced, along with the wiring harness and the throttle position sensor to no avail.
johnnyRacer
Mar 15, 2010 04:52 PM
jima
Dec 14, 2008 02:54 PM
mountanman101
Jan 27, 2008 05:25 PM
dustingb80
Sep 10, 2003 07:41 AM
