p0743 code on '98 expy
Old Nov 12, 2009 | 02:05 AM
johnnyRacer's Avatar
johnnyRacer
This code just came up the other day when the wife came back from dropping the kiddies off. Didn't find to much definative on a fix. Any ideas?
Old Nov 12, 2009 | 05:00 AM
projectSHO89's Avatar
projectSHO89
Check the TCC solenoid circuit for the correct resistances in the proper places.
You have one of the following: an open TCC solenoid, open internal transmission harness, bad connector at the transmission, an open in the vehicle harness, or a faulty PCM.
I'd start by unplugging the connector at the transmission and checking the resistance of the TCC solenoid and internal harness in one operation. I'd have to look up the value, but it's going to be somewhere between 10 and 50 ohms, most likely.
Old Mar 15, 2010 | 03:06 PM
johnnyRacer
Finally, got around to taking her into the shop. The tech checked for codes. He asked was the OD light flashing on the gear selector. I said no. He asked how long did the check engine light stay out when it was last cleared. I said 3-4 days. We also went on a test drive while he was taking a snapshot with his scanner. While out on the test drive he pointed out how the 1-2 shift was a little slow and the 3-4 shift dragged on for a long time. I explained how the 1-2 shift is like that in the morning on the first start up, but it gets better as the trans warms up. He suggest due to the number of orig. miles (142,000) I have, he would recommend an overhaul. Also, I did a trans flush and filter change last summer. The trans overhaul would cost $1800? I'm going out for a second opinion right now at AAMCO. What do you think about this first guy's suggestion?
Old Mar 15, 2010 | 04:52 PM
projectSHO89
Going to AAMCO (All Automatics Must Come Out) for a "second opinion" is like going to Congress for a second opinion when your doctor says you have 30 days to live....
Find an independent shop with a good reputation.
sudsmcduff
Jun 25, 2016 08:22 AM
RadioControlGuy85
16
Oct 14, 2015 11:35 AM
FordGuy85
2004 - 2008 F150
May 20, 2015 10:24 AM
03KingRanchF250
Nov 15, 2006 03:30 PM
la9
1997 - 2003 F150
Aug 7, 2003 02:33 PM
