Is the tranny shifting OK? Many times the sensor contacts become loose or dirty. Try cleaning them first, then reset the codes and see if they come back. If so, a good procedure to trouble shoot that code can be found off the motorcraft website for a nominal fee.
should i replace shift solenoid assembly and how do i do it
Hello,
Please check out our website. We have listed the codes and thier fixes for your vehicle. We can also supply you with the parts you need for your trans along with many upgrade and performance parts.
My Expy keeps throwing the code every 30-45 days after I reset it. Tranny shifts fine, so I'm guessing I have sensor contacts that are loose or dirty. Can you give me a detailed explanation (or picture) where these sensor contacts are? I'm not much of a car guy but willing to tackle jobs like these.
Thanks
Unfortunately, the guy who said that had no clue what he was talking about as there is no sensor that can cause this fault code.
You might have a connector problem where the harness plugs into the transmission. I'd suggest disconnecting the battery, then reseating the transmission's electrical connector to see if it's an intermittent mating problem. Inspect the pins for evidence of corrosion, damage, or for a pushed pin.
If the problem re-occurs, then you'll need more intensive diagnostic work.
