starter and ADD
Old Mar 18, 2016 | 09:44 PM
bcaughhorn's Avatar
bcaughhorn
so... what else do I need to order?
in my basket I have
1] hpx
2] frx
3) turbo reinstall kit
Old Mar 18, 2016 | 09:56 PM
AllaboutMPG's Avatar
AllaboutMPG
put some rags or covers on in the intakes. dont want to drop a nut washer in there
Old Mar 18, 2016 | 10:42 PM
jhl3's Avatar
jhl3
If you don't already have the complete Riffraff CAC boot replacement/upgrade, it is one of the best upgrades you can do.
Clay also has a kit to take that stock turbo up to a 38r equivalent...
Oh, this is about what you "need".
Plenum inserts are a good addition to keep from crimping the thin metal when you are torquing the plenum side of the plenum to spider boots.
Old Mar 19, 2016 | 05:19 AM
bcaughhorn's Avatar
bcaughhorn
Ok. I'll add a few things to the list. Thanks for the help
Old Mar 19, 2016 | 06:15 AM
bcaughhorn's Avatar
bcaughhorn
Man that's a expensive starter. Dang ADD is expensive.
1) frx
2) hpx
4) cac boot kit
5) plenum inserts
Next thing is to get the pressure washer out and clean it up. Of course some paint in in the future for her too.
Old Mar 19, 2016 | 09:35 AM
FiznUKa's Avatar
FiznUKa
You still need to take care of the EBPV don't know if that is the turbo reinstall or not but it is looking like a pretty good source of the oil leak.
Old Mar 19, 2016 | 09:45 AM
bcaughhorn's Avatar
bcaughhorn
I forgot to put that on my list. I ordered the rebuild kit for that too
Old Mar 19, 2016 | 12:24 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
T clamps might be a good idea of you don't already have them. They are far superior to the worm clamps that Ford put on.
http://www.riffraffdiesel.com/interc...-7-3l-99-5-03/
Old Mar 19, 2016 | 03:45 PM
coax9952's Avatar
coax9952
O rings, some o rings, and oh, some more o rings.....If your tore down that far.....might as well rebuild the fuel bowl.
Old Mar 19, 2016 | 05:24 PM
bcaughhorn's Avatar
bcaughhorn
The turbo reinstall kit has all the o-rings for it. Fuel bowl I guess will be another day..
Old Mar 20, 2016 | 05:09 AM
SGnAZ's Avatar
SGnAZ
Go here 1999-2003 Ford 7.3L
Do yourself a favor and replace fuel bowl and hpop orings.I just did both and was pretty easy.
I also replaced the pass side fuel line,you're already that far in,why not.
http://www.riffraffdiesel.com/passenger-side-fuel-line/
Old Mar 22, 2016 | 09:36 AM
bcaughhorn's Avatar
bcaughhorn
I put the new bellowed up pipes in after work yesterday. Talk about a pain in the ballz. I guess today will be what I originally intended and put the starter in. And clean some things up while I wait on that box with yellow tape to come in
Old Mar 25, 2016 | 06:56 AM
  #28
bcaughhorn's Avatar
bcaughhorn
Well I added to the list of parts ordered since it was all tore apart. So far I ordered the frx, hpx, plenum inserts, IC boots, pedestal rebuild kit (wasted money), spx billet wheel, bellowed up pipes, turbo pedestal with ebpv delete, high flow outlet with ebpv delete and I probably forgot something. Some parts are here. Waiting for the rest of the boxes to come in....
dvrjump
Jun 20, 2014 06:15 PM
wulfman
Jun 25, 2013 05:15 AM
waystro
Apr 13, 2013 07:54 AM
brooklyn
Mar 26, 2012 02:29 AM
mechelement
Feb 3, 2009 08:55 PM
