E40d help
Old Mar 15, 2016 | 11:01 PM
Dam pile's Avatar
Dam pile
E40d help
E40d no gears dropped transmission and took off up to the planetary gear housing everything looks new like it was rebuildt yesterday with no signs of wear anywear what could cause me to lose all gears except park besides planetary and input shaft
Old Mar 15, 2016 | 11:05 PM
Dam pile's Avatar
Dam pile
Acts like it's in neautral
Old Mar 16, 2016 | 09:44 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Did you look at both planetaries? Check both sun gears, the weld to the shell can break.
Old Mar 16, 2016 | 05:33 PM
sjwelds's Avatar
sjwelds
Hmmm wonder why two threads going by same guy same topic eh eh eh
Old Mar 17, 2016 | 12:44 PM
Dam pile's Avatar
Dam pile
Sorry I'm new I don't know how this works yet
Old Mar 19, 2016 | 11:14 AM
Macrobb's Avatar
Macrobb
Is there a way to put the transmission into a gear while on the test bench and rotate the various parts?
Old Mar 19, 2016 | 04:01 PM
Dam pile's Avatar
Dam pile
I don't belive so it's all controlled by the valve body and it has no valve body on it at this point
Mark Kovalsky
Only if you have a way to spin the converter at over 1000 RPM so it can build pressure. Without that none of the clutches will engage and you'll have neutral in every position.
Old Mar 19, 2016 | 04:54 PM
Dam pile's Avatar
Dam pile
Hey mark so is there anything in particular I should look for when I split the pump or will it be obvious if it's broken?
Flip4ford
Kansas Chapter
Oct 30, 2010 10:18 AM
Kerrie
Feb 4, 2008 05:07 PM
Cruiseomatic
Apr 30, 2006 09:49 AM
jim henderson
Jun 4, 2002 07:41 AM
